﻿{"name":"BIM Software Training ","description":"Ecco un altro sito BIM Software Training","url":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr","home":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr","gmt_offset":1,"timezone_string":"Europe\/Rome","page_for_posts":0,"page_on_front":17,"show_on_front":"page","namespaces":["oembed\/1.0","akismet\/v1","contact-form-7\/v1","jwt-auth\/v1","siteground-settings\/v1","siteground-optimizer\/v1","yoast\/v1","ldlms\/v1","wp\/v2","ldlms\/v2","zipwp\/v1","hfe\/v1","astra\/v1","elementor\/v1","zipwp-images\/v1","nps-survey\/v1","gutenberg-templates\/v1","wp-site-health\/v1","wp-block-editor\/v1","wp-abilities\/v1"],"authentication":{"application-passwords":{"endpoints":{"authorization":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-admin\/authorize-application.php"}}},"routes":{"\/":{"namespace":"","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/"}]}},"\/batch\/v1":{"namespace":"","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"validation":{"type":"string","enum":["require-all-validate","normal"],"default":"normal","required":false},"requests":{"type":"array","maxItems":25,"items":{"type":"object","properties":{"method":{"type":"string","enum":["POST","PUT","PATCH","DELETE"],"default":"POST"},"path":{"type":"string","required":true},"body":{"type":"object","properties":[],"additionalProperties":true},"headers":{"type":"object","properties":[],"additionalProperties":{"type":["string","array"],"items":{"type":"string"}}}}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/batch\/v1"}]}},"\/oembed\/1.0":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"oembed\/1.0","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/oembed\/1.0"}]}},"\/oembed\/1.0\/embed":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"L\u2019URL de la ressource \u00e0 parcourir pour obtenir les donn\u00e9es oEmbed.","type":"string","format":"uri","required":true},"format":{"default":"json","required":false},"maxwidth":{"default":600,"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/oembed\/1.0\/embed"}]}},"\/oembed\/1.0\/proxy":{"namespace":"oembed\/1.0","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"L\u2019URL de la ressource \u00e0 parcourir pour obtenir les donn\u00e9es oEmbed.","type":"string","format":"uri","required":true},"format":{"description":"Le format oEmbed \u00e0 utiliser.","type":"string","default":"json","enum":["json","xml"],"required":false},"maxwidth":{"description":"La largeur maximale du contenu embarqu\u00e9 en pixels.","type":"integer","default":600,"required":false},"maxheight":{"description":"La hauteur maximale du contenu embarqu\u00e9 oEmbed en pixels.","type":"integer","required":false},"discover":{"description":"D\u00e9termine s\u2019il faut ou non effectuer une requ\u00eate de d\u00e9couverte oEmbed vers d\u2019autres fournisseurs non autoris\u00e9s.","type":"boolean","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/oembed\/1.0\/proxy"}]}},"\/akismet\/v1":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"akismet\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/akismet\/v1"}]}},"\/akismet\/v1\/key":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"key":{"type":"string","description":"Une cl\u00e9 API Akismet \u00e0 12\u00a0caract\u00e8res. Disponible sur akismet.com\/account","required":true}}},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/akismet\/v1\/key"}]}},"\/akismet\/v1\/settings":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"akismet_strictness":{"type":"boolean","description":"Si oui, Akismet rejettera automatiquement les pires ind\u00e9sirables plut\u00f4t que de les placer dans le dossier des ind\u00e9sirables.","required":false},"akismet_show_user_comments_approved":{"type":"boolean","description":"Si oui, affiche le nombre de commentaires approuv\u00e9s \u00e0 c\u00f4t\u00e9 de chaque auteur de commentaire dans la page de liste de commentaires.","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/akismet\/v1\/settings"}]}},"\/akismet\/v1\/stats":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"interval":{"type":"string","description":"La p\u00e9riode sur laquelle les statistiques sont conserv\u00e9es. Options\u00a0: 60 jours, 6 mois, tous","default":"all","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/akismet\/v1\/stats"}]}},"\/akismet\/v1\/stats\/(?P<interval>[\\w+])":{"namespace":"akismet\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"interval":{"description":"La p\u00e9riode sur laquelle les statistiques sont conserv\u00e9es. Options\u00a0: 60 jours, 6 mois, tous","type":"string","required":false}}}]},"\/akismet\/v1\/alert":{"namespace":"akismet\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"key":{"type":"string","description":"Une cl\u00e9 API Akismet \u00e0 12\u00a0caract\u00e8res. Disponible sur akismet.com\/account","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"key":{"type":"string","description":"Une cl\u00e9 API Akismet \u00e0 12\u00a0caract\u00e8res. Disponible sur akismet.com\/account","required":false}}},{"methods":["DELETE"],"args":{"key":{"type":"string","description":"Une cl\u00e9 API Akismet \u00e0 12\u00a0caract\u00e8res. Disponible sur akismet.com\/account","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/akismet\/v1\/alert"}]}},"\/akismet\/v1\/webhook":{"namespace":"akismet\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/akismet\/v1\/webhook"}]}},"\/contact-form-7\/v1":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"contact-form-7\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/contact-form-7\/v1"}]}},"\/contact-form-7\/v1\/contact-forms":{"namespace":"contact-form-7\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/contact-form-7\/v1\/contact-forms"}]}},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)":{"namespace":"contact-form-7\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback":{"namespace":"contact-form-7\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/feedback\/schema":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/contact-form-7\/v1\/contact-forms\/(?P<id>\\d+)\/refill":{"namespace":"contact-form-7\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}]},"\/jwt-auth\/v1":{"namespace":"jwt-auth\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"jwt-auth\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/jwt-auth\/v1"}]}},"\/jwt-auth\/v1\/token":{"namespace":"jwt-auth\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/jwt-auth\/v1\/token"}]}},"\/jwt-auth\/v1\/token\/validate":{"namespace":"jwt-auth\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/jwt-auth\/v1\/token\/validate"}]}},"\/jwt-auth\/v1\/admin\/settings":{"namespace":"jwt-auth\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/jwt-auth\/v1\/admin\/settings"}]}},"\/jwt-auth\/v1\/admin\/status":{"namespace":"jwt-auth\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/jwt-auth\/v1\/admin\/status"}]}},"\/jwt-auth\/v1\/admin\/survey":{"namespace":"jwt-auth\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/jwt-auth\/v1\/admin\/survey"}]}},"\/jwt-auth\/v1\/admin\/survey\/status":{"namespace":"jwt-auth\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/jwt-auth\/v1\/admin\/survey\/status"}]}},"\/jwt-auth\/v1\/admin\/survey\/complete":{"namespace":"jwt-auth\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/jwt-auth\/v1\/admin\/survey\/complete"}]}},"\/jwt-auth\/v1\/admin\/survey\/dismissal":{"namespace":"jwt-auth\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/jwt-auth\/v1\/admin\/survey\/dismissal"}]}},"\/jwt-auth\/v1\/admin\/dashboard":{"namespace":"jwt-auth\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/jwt-auth\/v1\/admin\/dashboard"}]}},"\/jwt-auth\/v1\/admin\/notices\/dismiss":{"namespace":"jwt-auth\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"notice_id":{"type":"string","description":"The ID of the notice to dismiss","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/jwt-auth\/v1\/admin\/notices\/dismiss"}]}},"\/siteground-settings\/v1":{"namespace":"siteground-settings\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"siteground-settings\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-settings\/v1"}]}},"\/siteground-settings\/v1\/update-settings":{"namespace":"siteground-settings\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-settings\/v1\/update-settings"}]}},"\/siteground-optimizer\/v1":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"siteground-optimizer\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1"}]}},"\/siteground-optimizer\/v1\/webp-support":{"namespace":"siteground-optimizer\/v1","methods":["PUT","GET"],"endpoints":[{"methods":["PUT"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/webp-support"}]}},"\/siteground-optimizer\/v1\/reset-webp-conversion":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/reset-webp-conversion"}]}},"\/siteground-optimizer\/v1\/fetch-options":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/fetch-options"}]}},"\/siteground-optimizer\/v1\/enable-option":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/enable-option"}]}},"\/siteground-optimizer\/v1\/disable-option":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/disable-option"}]}},"\/siteground-optimizer\/v1\/combine-css":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/combine-css"}]}},"\/siteground-optimizer\/v1\/preload-combined-css":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/preload-combined-css"}]}},"\/siteground-optimizer\/v1\/fetch-options\/(?P<page_id>[^\/]+)":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"page_id":{"required":false}}}]},"\/siteground-optimizer\/v1\/purge-rest-cache":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/purge-rest-cache"}]}},"\/siteground-optimizer\/v1\/logged-in-cache":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/logged-in-cache"}]}},"\/siteground-optimizer\/v1\/enable-gzip-compression":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/enable-gzip-compression"}]}},"\/siteground-optimizer\/v1\/enable-browser-caching":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/enable-browser-caching"}]}},"\/siteground-optimizer\/v1\/optimize-css":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/optimize-css"}]}},"\/siteground-optimizer\/v1\/optimize-javascript":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/optimize-javascript"}]}},"\/siteground-optimizer\/v1\/combine-javascript":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/combine-javascript"}]}},"\/siteground-optimizer\/v1\/optimize-javascript-async":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/optimize-javascript-async"}]}},"\/siteground-optimizer\/v1\/optimize-html":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/optimize-html"}]}},"\/siteground-optimizer\/v1\/optimize-web-fonts":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/optimize-web-fonts"}]}},"\/siteground-optimizer\/v1\/remove-query-strings":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/remove-query-strings"}]}},"\/siteground-optimizer\/v1\/disable-emojis":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/disable-emojis"}]}},"\/siteground-optimizer\/v1\/lazyload-images":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/lazyload-images"}]}},"\/siteground-optimizer\/v1\/backup-media":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/backup-media"}]}},"\/siteground-optimizer\/v1\/enable-cache":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/enable-cache"}]}},"\/siteground-optimizer\/v1\/memcached":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/memcached"}]}},"\/siteground-optimizer\/v1\/autoflush-cache":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/autoflush-cache"}]}},"\/siteground-optimizer\/v1\/purge-cache":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/purge-cache"}]}},"\/siteground-optimizer\/v1\/user-agent-header":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/user-agent-header"}]}},"\/siteground-optimizer\/v1\/test-url-cache":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/test-url-cache"}]}},"\/siteground-optimizer\/v1\/enable-memcache":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/enable-memcache"}]}},"\/siteground-optimizer\/v1\/disable-memcache":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/disable-memcache"}]}},"\/siteground-optimizer\/v1\/file-caching":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/file-caching"}]}},"\/siteground-optimizer\/v1\/file-caching-settings":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/file-caching-settings"}]}},"\/siteground-optimizer\/v1\/enable-multisite-optimization":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/enable-multisite-optimization"}]}},"\/siteground-optimizer\/v1\/disable-multisite-optimization":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/disable-multisite-optimization"}]}},"\/siteground-optimizer\/v1\/run-analysis":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/run-analysis"}]}},"\/siteground-optimizer\/v1\/exclude\/(?P<type>[^\/]+)":{"namespace":"siteground-optimizer\/v1","methods":["PUT","PUT","PUT","PUT","PUT","PUT","PUT","PUT","PUT","PUT","PUT","PUT"],"endpoints":[{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}},{"methods":["PUT"],"args":{"type":{"required":false}}}]},"\/siteground-optimizer\/v1\/feature-popup\/(?P<type>[^\/]+)":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"required":false},"page_id":{"required":false}}}]},"\/siteground-optimizer\/v1\/performance-report":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/performance-report"}]}},"\/siteground-optimizer\/v1\/perf-notification-email":{"namespace":"siteground-optimizer\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/perf-notification-email"}]}},"\/siteground-optimizer\/v1\/optimize-images":{"namespace":"siteground-optimizer\/v1","methods":["PUT","GET"],"endpoints":[{"methods":["PUT"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/optimize-images"}]}},"\/siteground-optimizer\/v1\/reset-images-optimization":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/reset-images-optimization"}]}},"\/siteground-optimizer\/v1\/preview-image(?:\/(?P<id>\\d+))?":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[{"required":false}]}]},"\/siteground-optimizer\/v1\/image-resize":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/image-resize"}]}},"\/siteground-optimizer\/v1\/ssl":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/ssl"}]}},"\/siteground-optimizer\/v1\/fix-insecure-content":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/fix-insecure-content"}]}},"\/siteground-optimizer\/v1\/database-optimization":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/database-optimization"}]}},"\/siteground-optimizer\/v1\/heartbeat\/(?P<location>[^\/]+)":{"namespace":"siteground-optimizer\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":{"location":{"required":false}}}]},"\/siteground-optimizer\/v1\/notifications":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/notifications"}]}},"\/siteground-optimizer\/v1\/hardening":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/hardening"}]}},"\/siteground-optimizer\/v1\/e-book":{"namespace":"siteground-optimizer\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/e-book"}]}},"\/siteground-optimizer\/v1\/rate":{"namespace":"siteground-optimizer\/v1","methods":["PUT","GET"],"endpoints":[{"methods":["PUT"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/siteground-optimizer\/v1\/rate"}]}},"\/yoast\/v1":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"yoast\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1"}]}},"\/yoast\/v1\/file_size":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"type":"string","description":"The url to retrieve","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/file_size"}]}},"\/yoast\/v1\/statistics":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/statistics"}]}},"\/yoast\/v1\/ai_generator\/callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/ai_generator\/callback"}]}},"\/yoast\/v1\/ai_generator\/refresh_callback":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"access_jwt":{"type":"string","description":"The access JWT.","required":true},"refresh_jwt":{"type":"string","description":"The JWT to be used when the access JWT needs to be refreshed.","required":true},"code_challenge":{"type":"string","description":"The SHA266 of the verification code used to check the authenticity of a callback call.","required":true},"user_id":{"type":"integer","description":"The id of the user associated to the code verifier.","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/ai_generator\/refresh_callback"}]}},"\/yoast\/v1\/ai_generator\/consent":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"consent":{"type":"boolean","description":"Whether the consent to use AI-based services has been given by the user.","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/ai_generator\/consent"}]}},"\/yoast\/v1\/ai\/free_sparks":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/ai\/free_sparks"}]}},"\/yoast\/v1\/ai_generator\/bust_subscription_cache":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/ai_generator\/bust_subscription_cache"}]}},"\/yoast\/v1\/ai_generator\/get_suggestions":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"type":{"type":"string","enum":["seo-title","meta-description","product-seo-title","product-meta-description","product-taxonomy-seo-title","product-taxonomy-meta-description","taxonomy-seo-title","taxonomy-meta-description"],"description":"The type of suggestion requested.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for suggestions.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":true},"language":{"type":"string","description":"The language the post is written in.","required":true},"platform":{"type":"string","enum":["Google","Facebook","Twitter"],"description":"The platform the post is intended for.","required":true},"editor":{"type":"string","enum":["classic","elementor","gutenberg"],"description":"The current editor.","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/ai_generator\/get_suggestions"}]}},"\/yoast\/v1\/ai_generator\/get_usage":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_woo_product_entity":{"type":"boolean","default":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/ai_generator\/get_usage"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"postTypeName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-post-type"}]}},"\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"taxonomyName":{"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/new-content-type-visibility\/dismiss-taxonomy"}]}},"\/yoast\/v1\/site_kit_configuration_permanent_dismissal":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"is_dismissed":{"type":"bool","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/site_kit_configuration_permanent_dismissal"}]}},"\/yoast\/v1\/readability_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/readability_scores"}]}},"\/yoast\/v1\/seo_scores":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"contentType":{"type":"string","required":true},"taxonomy":{"type":"string","default":"","required":false},"term":{"type":"integer","default":null,"required":false},"troubleshooting":{"type":"bool","default":null,"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/seo_scores"}]}},"\/yoast\/v1\/setup_steps_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"setup_widget_loaded":{"type":"string","enum":["yes","no"],"required":false},"first_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"last_interaction_stage":{"type":"string","enum":["install","activate","setup","grantConsent","successfullyConnected"],"required":false},"setup_widget_temporarily_dismissed":{"type":"string","enum":["yes","no"],"required":false},"setup_widget_permanently_dismissed":{"type":"string","enum":["yes","no"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/setup_steps_tracking"}]}},"\/yoast\/v1\/introductions\/(?P<introduction_id>[\\w-]+)\/seen":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"introduction_id":{"type":"string","required":true},"is_seen":{"type":"bool","default":true,"required":false}}}]},"\/yoast\/v1\/wistia_embed_permission":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"value":{"type":"bool","default":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/wistia_embed_permission"}]}},"\/yoast\/v1\/available_posts":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"search":{"type":"string","default":"","required":false},"postType":{"type":"string","default":"page","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/available_posts"}]}},"\/yoast\/v1\/alerts\/dismiss":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"key":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/alerts\/dismiss"}]}},"\/yoast\/v1\/configuration\/site_representation":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"company_or_person":{"type":"string","enum":["company","person"],"required":true},"company_name":{"type":"string","required":false},"company_logo":{"type":"string","required":false},"company_logo_id":{"type":"integer","required":false},"person_logo":{"type":"string","required":false},"person_logo_id":{"type":"integer","required":false},"company_or_person_user_id":{"type":"integer","required":false},"description":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/configuration\/site_representation"}]}},"\/yoast\/v1\/configuration\/social_profiles":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"facebook_site":{"type":"string","required":false},"twitter_site":{"type":"string","required":false},"other_social_urls":{"type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/configuration\/social_profiles"}]}},"\/yoast\/v1\/configuration\/check_capability":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"user_id":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/configuration\/check_capability"}]}},"\/yoast\/v1\/configuration\/enable_tracking":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"tracking":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/configuration\/enable_tracking"}]}},"\/yoast\/v1\/configuration\/save_configuration_state":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"finishedSteps":{"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/configuration\/save_configuration_state"}]}},"\/yoast\/v1\/configuration\/get_configuration_state":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/configuration\/get_configuration_state"}]}},"\/yoast\/v1\/import\/(?P<plugin>[\\w-]+)\/(?P<type>[\\w-]+)":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}]},"\/yoast\/v1\/get_head":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/get_head"}]}},"\/yoast\/v1\/indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/indexing\/posts"}]}},"\/yoast\/v1\/indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/indexing\/terms"}]}},"\/yoast\/v1\/indexing\/post-type-archives":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/indexing\/post-type-archives"}]}},"\/yoast\/v1\/indexing\/general":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/indexing\/general"}]}},"\/yoast\/v1\/indexing\/prepare":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/indexing\/prepare"}]}},"\/yoast\/v1\/indexing\/indexables-complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/indexing\/indexables-complete"}]}},"\/yoast\/v1\/indexing\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/indexing\/complete"}]}},"\/yoast\/v1\/link-indexing\/posts":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/link-indexing\/posts"}]}},"\/yoast\/v1\/link-indexing\/terms":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/link-indexing\/terms"}]}},"\/yoast\/v1\/integrations\/set_active":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"active":{"type":"boolean","required":true},"integration":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/integrations\/set_active"}]}},"\/yoast\/v1\/meta\/search":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/meta\/search"}]}},"\/yoast\/v1\/semrush\/authenticate":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/semrush\/authenticate"}]}},"\/yoast\/v1\/semrush\/country_code":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/semrush\/country_code"}]}},"\/yoast\/v1\/semrush\/related_keyphrases":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"keyphrase":{"required":true},"country_code":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/semrush\/related_keyphrases"}]}},"\/yoast\/v1\/workouts":{"namespace":"yoast\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"cornerstone":{"required":true},"orphaned":{"required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/workouts"}]}},"\/yoast\/v1\/complete_task":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"options":{"type":"object","properties":{"task":{"type":"string","required":true,"sanitize_callback":"sanitize_text_field"}},"required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/complete_task"}]}},"\/yoast\/v1\/get_tasks":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"options":{"type":"object","properties":{"filter":{"type":"string","required":false,"sanitize_callback":"sanitize_text_field"},"limit":{"type":"int","required":false,"sanitize_callback":"absint"}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/get_tasks"}]}},"\/yoast\/v1\/ai\/optimize":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"assessment":{"type":"string","enum":["seo-keyphrase-introduction","seo-keyphrase-density","seo-keyphrase-distribution","seo-keyphrase-subheadings","read-sentence-length","read-paragraph-length"],"description":"The assessment.","required":true},"language":{"type":"string","description":"The language the post is written in.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for suggestions.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":false},"synonyms":{"type":"string","description":"The synonyms for the focus keyphrase.","required":false},"editor":{"type":"string","enum":["Classic","Gutenberg"],"description":"The editor type, either Classic or Gutenberg.","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/ai\/optimize"}]}},"\/yoast\/v1\/ai\/summarize":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"language":{"type":"string","description":"The language the post is written in.","required":true},"prompt_content":{"type":"string","description":"The content needed by the prompt to ask for a summary.","required":true},"focus_keyphrase":{"type":"string","description":"The focus keyphrase associated to the post.","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/ai\/summarize"}]}},"\/yoast\/v1\/link_suggestions":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"prominent_words":{"type":"object","description":"Stems of prominent words and their term frequencies we want link suggestions based on","required":true},"object_id":{"type":"integer","description":"The object id of the current indexable.","required":true},"object_type":{"type":"string","description":"The object type of the current indexable.","required":true},"limit":{"default":5,"type":"integer","description":"The maximum number of link suggestions to retrieve","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/link_suggestions"}]}},"\/yoast\/v1\/prominent_words\/get_content":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/prominent_words\/get_content"}]}},"\/yoast\/v1\/prominent_words\/complete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/prominent_words\/complete"}]}},"\/yoast\/v1\/prominent_words\/save":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"data":{"type":"array","items":{"type":"object","properties":{"object_id":{"type":"number","required":true},"prominent_words":{"type":"object","required":false}}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/prominent_words\/save"}]}},"\/yoast\/v1\/workouts\/noindex":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"object_id":{"type":"integer","required":true},"object_type":{"type":"string","required":true},"object_sub_type":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/workouts\/noindex"}]}},"\/yoast\/v1\/workouts\/remove_redirect":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"object_id":{"type":"integer","required":true},"object_type":{"type":"string","required":true},"object_sub_type":{"type":"string","required":true},"permalink":{"type":"string","required":true},"redirect_url":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/workouts\/remove_redirect"}]}},"\/yoast\/v1\/workouts\/link_suggestions":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"indexableId":{"type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/workouts\/link_suggestions"}]}},"\/yoast\/v1\/workouts\/last_updated":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"postId":{"type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/workouts\/last_updated"}]}},"\/yoast\/v1\/workouts\/cornerstone_data":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/workouts\/cornerstone_data"}]}},"\/yoast\/v1\/workouts\/enable_cornerstone":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"object_id":{"type":"integer","required":true},"object_type":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/workouts\/enable_cornerstone"}]}},"\/ldlms\/v1":{"namespace":"ldlms\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"ldlms\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v1"}]}},"\/ldlms\/v1\/echo":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v1\/echo"}]}},"\/wp\/v2":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2"}]}},"\/wp\/v2\/sfwd-courses":{"namespace":"wp\/v2","methods":["GET","POST","GET","POST","GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":[]},{"methods":["POST"],"allow_batch":{"v1":true},"args":[]},{"methods":["GET"],"allow_batch":{"v1":true},"args":[]},{"methods":["POST"],"allow_batch":{"v1":true},"args":[]},{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"course_materials":{"description":"Cours Materials","type":"html","required":false},"course_price_type":{"default":"open","description":"Cours Price Type","type":"string","enum":["open","closed","free","buynow","subscribe"],"required":false},"custom_button_label":{"description":"Custom Button Label","type":"text","required":false},"custom_button_url":{"description":"URL de bouton personnalis\u00e9","type":"text","required":false},"course_price":{"description":"Cours Prix","type":"text","required":false},"course_prerequisite_enabled":{"default":false,"description":"Activer les pr\u00e9-requis du Cours","type":"boolean","required":false},"course_prerequisite":{"default":[],"description":"Cours Prerequisites","type":"array","required":false},"course_prerequisite_compare":{"default":"ANY","description":"Cours Prerequisites Compare","type":"string","enum":["ANY","ALL"],"required":false},"course_points_enabled":{"description":"Activer Cours les Points","type":"boolean","required":false},"course_points":{"description":"Cours Points","type":"number","required":false},"course_points_access":{"description":"Cours Points Access","type":"number","required":false},"course_disable_lesson_progression":{"default":0,"description":"Disable Le\u00e7on Progression","type":"boolean","required":false},"expire_access":{"description":"Dur\u00e9e d\u00e9finie","type":"boolean","required":false},"expire_access_days":{"description":"Acc\u00e8s ferm\u00e9 apr\u00e8s X jours","type":"number","required":false},"expire_access_delete_progress":{"description":"Delete Cours and Quiz Data After Expiration","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/sfwd-courses"}]}},"\/wp\/v2\/sfwd-courses\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE","GET","POST","PUT","PATCH","DELETE","GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe de ce post si il est prot\u00e9g\u00e9 par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"course_materials":{"description":"Cours Materials","type":"html","required":false},"course_price_type":{"description":"Cours Price Type","type":"string","enum":["open","closed","free","buynow","subscribe"],"required":false},"custom_button_label":{"description":"Custom Button Label","type":"text","required":false},"custom_button_url":{"description":"URL de bouton personnalis\u00e9","type":"text","required":false},"course_price":{"description":"Cours Prix","type":"text","required":false},"course_prerequisite_enabled":{"description":"Activer les pr\u00e9-requis du Cours","type":"boolean","required":false},"course_prerequisite":{"description":"Cours Prerequisites","type":"array","required":false},"course_prerequisite_compare":{"description":"Cours Prerequisites Compare","type":"string","enum":["ANY","ALL"],"required":false},"course_points_enabled":{"description":"Activer Cours les Points","type":"boolean","required":false},"course_points":{"description":"Cours Points","type":"number","required":false},"course_points_access":{"description":"Cours Points Access","type":"number","required":false},"course_disable_lesson_progression":{"description":"Disable Le\u00e7on Progression","type":"boolean","required":false},"expire_access":{"description":"Dur\u00e9e d\u00e9finie","type":"boolean","required":false},"expire_access_days":{"description":"Acc\u00e8s ferm\u00e9 apr\u00e8s X jours","type":"number","required":false},"expire_access_delete_progress":{"description":"Delete Cours and Quiz Data After Expiration","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}},{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe de ce post si il est prot\u00e9g\u00e9 par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"course_materials":{"description":"Cours Materials","type":"html","required":false},"course_price_type":{"description":"Cours Price Type","type":"string","enum":["open","closed","free","buynow","subscribe"],"required":false},"custom_button_label":{"description":"Custom Button Label","type":"text","required":false},"custom_button_url":{"description":"URL de bouton personnalis\u00e9","type":"text","required":false},"course_price":{"description":"Cours Prix","type":"text","required":false},"course_prerequisite_enabled":{"description":"Activer les pr\u00e9-requis du Cours","type":"boolean","required":false},"course_prerequisite":{"description":"Cours Prerequisites","type":"array","required":false},"course_prerequisite_compare":{"description":"Cours Prerequisites Compare","type":"string","enum":["ANY","ALL"],"required":false},"course_points_enabled":{"description":"Activer Cours les Points","type":"boolean","required":false},"course_points":{"description":"Cours Points","type":"number","required":false},"course_points_access":{"description":"Cours Points Access","type":"number","required":false},"course_disable_lesson_progression":{"description":"Disable Le\u00e7on Progression","type":"boolean","required":false},"expire_access":{"description":"Dur\u00e9e d\u00e9finie","type":"boolean","required":false},"expire_access_days":{"description":"Acc\u00e8s ferm\u00e9 apr\u00e8s X jours","type":"number","required":false},"expire_access_delete_progress":{"description":"Delete Cours and Quiz Data After Expiration","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}},{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"course_materials":{"description":"Cours Materials","type":"html","required":false},"course_price_type":{"description":"Cours Price Type","type":"string","enum":["open","closed","free","buynow","subscribe"],"required":false},"custom_button_label":{"description":"Custom Button Label","type":"text","required":false},"custom_button_url":{"description":"URL de bouton personnalis\u00e9","type":"text","required":false},"course_price":{"description":"Cours Prix","type":"text","required":false},"course_prerequisite_enabled":{"description":"Activer les pr\u00e9-requis du Cours","type":"boolean","required":false},"course_prerequisite":{"description":"Cours Prerequisites","type":"array","required":false},"course_prerequisite_compare":{"description":"Cours Prerequisites Compare","type":"string","enum":["ANY","ALL"],"required":false},"course_points_enabled":{"description":"Activer Cours les Points","type":"boolean","required":false},"course_points":{"description":"Cours Points","type":"number","required":false},"course_points_access":{"description":"Cours Points Access","type":"number","required":false},"course_disable_lesson_progression":{"description":"Disable Le\u00e7on Progression","type":"boolean","required":false},"expire_access":{"description":"Dur\u00e9e d\u00e9finie","type":"boolean","required":false},"expire_access_days":{"description":"Acc\u00e8s ferm\u00e9 apr\u00e8s X jours","type":"number","required":false},"expire_access_delete_progress":{"description":"Delete Cours and Quiz Data After Expiration","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/ldlms\/v1\/sfwd-courses":{"namespace":"ldlms\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"course_materials":{"description":"Cours Materials","type":"html","required":false},"course_price_type":{"default":"open","description":"Cours Price Type","type":"string","enum":["open","closed","free","buynow","subscribe"],"required":false},"custom_button_label":{"description":"Custom Button Label","type":"text","required":false},"custom_button_url":{"description":"URL de bouton personnalis\u00e9","type":"text","required":false},"course_price":{"description":"Cours Prix","type":"text","required":false},"course_prerequisite_enabled":{"default":false,"description":"Activer les pr\u00e9-requis du Cours","type":"boolean","required":false},"course_prerequisite":{"default":[],"description":"Cours Prerequisites","type":"array","required":false},"course_prerequisite_compare":{"default":"ANY","description":"Cours Prerequisites Compare","type":"string","enum":["ANY","ALL"],"required":false},"course_points_enabled":{"description":"Activer Cours les Points","type":"boolean","required":false},"course_points":{"description":"Cours Points","type":"number","required":false},"course_points_access":{"description":"Cours Points Access","type":"number","required":false},"course_disable_lesson_progression":{"default":0,"description":"Disable Le\u00e7on Progression","type":"boolean","required":false},"expire_access":{"description":"Dur\u00e9e d\u00e9finie","type":"boolean","required":false},"expire_access_days":{"description":"Acc\u00e8s ferm\u00e9 apr\u00e8s X jours","type":"number","required":false},"expire_access_delete_progress":{"description":"Delete Cours and Quiz Data After Expiration","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v1\/sfwd-courses"}]}},"\/ldlms\/v1\/sfwd-courses\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe de ce post si il est prot\u00e9g\u00e9 par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":true},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"course_materials":{"description":"Cours Materials","type":"html","required":false},"course_price_type":{"description":"Cours Price Type","type":"string","enum":["open","closed","free","buynow","subscribe"],"required":false},"custom_button_label":{"description":"Custom Button Label","type":"text","required":false},"custom_button_url":{"description":"URL de bouton personnalis\u00e9","type":"text","required":false},"course_price":{"description":"Cours Prix","type":"text","required":false},"course_prerequisite_enabled":{"description":"Activer les pr\u00e9-requis du Cours","type":"boolean","required":false},"course_prerequisite":{"description":"Cours Prerequisites","type":"array","required":false},"course_prerequisite_compare":{"description":"Cours Prerequisites Compare","type":"string","enum":["ANY","ALL"],"required":false},"course_points_enabled":{"description":"Activer Cours les Points","type":"boolean","required":false},"course_points":{"description":"Cours Points","type":"number","required":false},"course_points_access":{"description":"Cours Points Access","type":"number","required":false},"course_disable_lesson_progression":{"description":"Disable Le\u00e7on Progression","type":"boolean","required":false},"expire_access":{"description":"Dur\u00e9e d\u00e9finie","type":"boolean","required":false},"expire_access_days":{"description":"Acc\u00e8s ferm\u00e9 apr\u00e8s X jours","type":"number","required":false},"expire_access_delete_progress":{"description":"Delete Cours and Quiz Data After Expiration","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}}]},"\/ldlms\/v1\/sfwd-courses\/(?P<id>[\\d]+)\/steps":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Cours ID to enroll user into.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Filter returned results by step type.","type":"string","default":"all","enum":["all","h","l","t","r"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Cours ID to enroll user into.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Filter returned results by step type.","type":"string","default":"all","enum":["all","h","l","t","r"],"required":false}}}]},"\/ldlms\/v1\/sfwd-courses\/(?P<id>[\\d]+)\/users":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Cours ID.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"fields":{"description":"Returned values.","type":"string","default":"ids","enum":["ids","objects"],"required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"default":"asc","description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","enum":["asc","desc"],"type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"roles":{"description":"Limiter le r\u00e9sultat aux comptes correspondants \u00e0 au moins un r\u00f4le sp\u00e9cifique fourni. Accepte les listes de type CSV ou les r\u00f4les uniques.","type":"array","items":{"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux comptes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Cours ID.","type":"integer","required":true},"user_ids":{"description":"User IDs to enroll into cours. Limit 50 per request.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Cours ID.","type":"integer","required":true},"user_ids":{"description":"User IDs to remove from groupe. Limit 50 per request.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/wp\/v2\/groups":{"namespace":"wp\/v2","methods":["GET","POST","GET","POST","GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":[]},{"methods":["POST"],"allow_batch":{"v1":true},"args":[]},{"methods":["GET"],"allow_batch":{"v1":true},"args":[]},{"methods":["POST"],"allow_batch":{"v1":true},"args":[]},{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"ld_group_category":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_group_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_group_category_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_group_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_group_tag":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_group_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_group_tag_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_group_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"ld_group_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_category.","type":"array","items":{"type":"integer"},"required":false},"ld_group_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_tag.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/groups"}]}},"\/wp\/v2\/groups\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE","GET","POST","PUT","PATCH","DELETE","GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe de ce post si il est prot\u00e9g\u00e9 par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"ld_group_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_category.","type":"array","items":{"type":"integer"},"required":false},"ld_group_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_tag.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}},{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe de ce post si il est prot\u00e9g\u00e9 par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"ld_group_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_category.","type":"array","items":{"type":"integer"},"required":false},"ld_group_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_tag.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}},{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"ld_group_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_category.","type":"array","items":{"type":"integer"},"required":false},"ld_group_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_tag.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/ldlms\/v1\/sfwd-courses\/(?P<id>[\\d]+)\/groups":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Cours ID to enroll into.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"fields":{"description":"Returned values.","type":"string","default":"ids","enum":["ids","objects"],"required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Cours ID to enroll into.","type":"integer","required":true},"group_ids":{"description":"Groupe IDs to enroll into Cours.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Cours ID to enroll into.","type":"integer","required":true},"group_ids":{"description":"Groupe IDs to remove from Cours.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/wp\/v2\/sfwd-lessons":{"namespace":"wp\/v2","methods":["GET","POST","GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":[]},{"methods":["POST"],"allow_batch":{"v1":true},"args":[]},{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"course":{"description":"Limit results to be within a specific Cours. Required for non-admin users.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"lesson_materials":{"description":"Le\u00e7on Documents","type":"html","required":false},"forced_lesson_time":{"default":"","description":"Forced Le\u00e7on Timer","type":"text","required":false},"lesson_assignment_upload":{"default":0,"description":"Devoirs \u00e0 t\u00e9l\u00e9charger","type":"boolean","required":false},"auto_approve_assignment":{"default":"on","description":"Approuver Automatiquement les Devoirs","type":"boolean","required":false},"assignment_upload_limit_count":{"default":"1","description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_deletion_enabled":{"default":0,"description":"Allow Student to Delete own Assignment(s)","type":"boolean","required":false},"lesson_assignment_points_enabled":{"default":0,"description":"Donner des points pour le Devoir","type":"boolean","required":false},"lesson_assignment_points_amount":{"default":0,"description":"Donner les Nombre de Points pour le Devoir","type":"number","required":false},"assignment_upload_limit_extensions":{"default":"","description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"default":"","description":"Allowed File Size","type":"text","required":false},"visible_after":{"default":0,"description":"Rendre cette Le\u00e7on visible X jours apr\u00e8s l&#039;inscription.","type":"number","required":false},"visible_after_specific_date":{"description":"Make Le\u00e7on Visible on Specific Date","type":"wp_date_selector","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/sfwd-lessons"}]}},"\/wp\/v2\/sfwd-lessons\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE","GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe de ce post si il est prot\u00e9g\u00e9 par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}},{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"lesson_materials":{"description":"Le\u00e7on Documents","type":"html","required":false},"forced_lesson_time":{"description":"Forced Le\u00e7on Timer","type":"text","required":false},"lesson_assignment_upload":{"description":"Devoirs \u00e0 t\u00e9l\u00e9charger","type":"boolean","required":false},"auto_approve_assignment":{"description":"Approuver Automatiquement les Devoirs","type":"boolean","required":false},"assignment_upload_limit_count":{"description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_deletion_enabled":{"description":"Allow Student to Delete own Assignment(s)","type":"boolean","required":false},"lesson_assignment_points_enabled":{"description":"Donner des points pour le Devoir","type":"boolean","required":false},"lesson_assignment_points_amount":{"description":"Donner les Nombre de Points pour le Devoir","type":"number","required":false},"assignment_upload_limit_extensions":{"description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"description":"Allowed File Size","type":"text","required":false},"visible_after":{"description":"Rendre cette Le\u00e7on visible X jours apr\u00e8s l&#039;inscription.","type":"number","required":false},"visible_after_specific_date":{"description":"Make Le\u00e7on Visible on Specific Date","type":"wp_date_selector","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/ldlms\/v1\/sfwd-lessons":{"namespace":"ldlms\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"course":{"description":"Limit results to be within a specific Cours. Required for non-admin users.","type":"integer","required":false}}},{"methods":["POST"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"lesson_materials":{"description":"Le\u00e7on Documents","type":"html","required":false},"forced_lesson_time":{"default":"","description":"Forced Le\u00e7on Timer","type":"text","required":false},"lesson_assignment_upload":{"default":0,"description":"Devoirs \u00e0 t\u00e9l\u00e9charger","type":"boolean","required":false},"auto_approve_assignment":{"default":"on","description":"Approuver Automatiquement les Devoirs","type":"boolean","required":false},"assignment_upload_limit_count":{"default":"1","description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_deletion_enabled":{"default":0,"description":"Allow Student to Delete own Assignment(s)","type":"boolean","required":false},"lesson_assignment_points_enabled":{"default":0,"description":"Donner des points pour le Devoir","type":"boolean","required":false},"lesson_assignment_points_amount":{"default":0,"description":"Donner les Nombre de Points pour le Devoir","type":"number","required":false},"assignment_upload_limit_extensions":{"default":"","description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"default":"","description":"Allowed File Size","type":"text","required":false},"visible_after":{"default":0,"description":"Rendre cette Le\u00e7on visible X jours apr\u00e8s l&#039;inscription.","type":"number","required":false},"visible_after_specific_date":{"description":"Make Le\u00e7on Visible on Specific Date","type":"wp_date_selector","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v1\/sfwd-lessons"}]}},"\/ldlms\/v1\/sfwd-lessons\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe de ce post si il est prot\u00e9g\u00e9 par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"lesson_materials":{"description":"Le\u00e7on Documents","type":"html","required":false},"forced_lesson_time":{"description":"Forced Le\u00e7on Timer","type":"text","required":false},"lesson_assignment_upload":{"description":"Devoirs \u00e0 t\u00e9l\u00e9charger","type":"boolean","required":false},"auto_approve_assignment":{"description":"Approuver Automatiquement les Devoirs","type":"boolean","required":false},"assignment_upload_limit_count":{"description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_deletion_enabled":{"description":"Allow Student to Delete own Assignment(s)","type":"boolean","required":false},"lesson_assignment_points_enabled":{"description":"Donner des points pour le Devoir","type":"boolean","required":false},"lesson_assignment_points_amount":{"description":"Donner les Nombre de Points pour le Devoir","type":"number","required":false},"assignment_upload_limit_extensions":{"description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"description":"Allowed File Size","type":"text","required":false},"visible_after":{"description":"Rendre cette Le\u00e7on visible X jours apr\u00e8s l&#039;inscription.","type":"number","required":false},"visible_after_specific_date":{"description":"Make Le\u00e7on Visible on Specific Date","type":"wp_date_selector","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}}]},"\/wp\/v2\/sfwd-topic":{"namespace":"wp\/v2","methods":["GET","POST","GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":[]},{"methods":["POST"],"allow_batch":{"v1":true},"args":[]},{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"ld_topic_category":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_topic_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_topic_category_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_topic_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_topic_tag":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_topic_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_topic_tag_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_topic_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"course":{"description":"Limit results to be within a specific Cours. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Le\u00e7on. Must be used with Cours parameter.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"ld_topic_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_topic_category.","type":"array","items":{"type":"integer"},"required":false},"ld_topic_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_topic_tag.","type":"array","items":{"type":"integer"},"required":false},"topic_materials":{"description":"Chapitre Documents","type":"html","required":false},"forced_lesson_time":{"default":"","description":"Forced Chapitre Timer","type":"text","required":false},"lesson_assignment_upload":{"default":0,"description":"Devoirs \u00e0 t\u00e9l\u00e9charger","type":"boolean","required":false},"auto_approve_assignment":{"default":"on","description":"Approuver Automatiquement les Devoirs","type":"boolean","required":false},"assignment_upload_limit_count":{"default":"1","description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_points_enabled":{"default":0,"description":"Donner des points pour le Devoir","type":"boolean","required":false},"lesson_assignment_points_amount":{"default":0,"description":"Donner les Nombre de Points pour le Devoir","type":"number","required":false},"assignment_upload_limit_extensions":{"default":"","description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"default":"","description":"Allowed File Size","type":"text","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/sfwd-topic"}]}},"\/wp\/v2\/sfwd-topic\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE","GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe de ce post si il est prot\u00e9g\u00e9 par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"ld_topic_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_topic_category.","type":"array","items":{"type":"integer"},"required":false},"ld_topic_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_topic_tag.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}},{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"ld_topic_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_topic_category.","type":"array","items":{"type":"integer"},"required":false},"ld_topic_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_topic_tag.","type":"array","items":{"type":"integer"},"required":false},"topic_materials":{"description":"Chapitre Documents","type":"html","required":false},"forced_lesson_time":{"description":"Forced Chapitre Timer","type":"text","required":false},"lesson_assignment_upload":{"description":"Devoirs \u00e0 t\u00e9l\u00e9charger","type":"boolean","required":false},"auto_approve_assignment":{"description":"Approuver Automatiquement les Devoirs","type":"boolean","required":false},"assignment_upload_limit_count":{"description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_points_enabled":{"description":"Donner des points pour le Devoir","type":"boolean","required":false},"lesson_assignment_points_amount":{"description":"Donner les Nombre de Points pour le Devoir","type":"number","required":false},"assignment_upload_limit_extensions":{"description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"description":"Allowed File Size","type":"text","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/ldlms\/v1\/sfwd-topic":{"namespace":"ldlms\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"ld_topic_category":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_topic_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_topic_category_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_topic_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_topic_tag":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_topic_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_topic_tag_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_topic_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"course":{"description":"Limit results to be within a specific Cours. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Le\u00e7on. Must be used with Cours parameter.","type":"integer","required":false}}},{"methods":["POST"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"ld_topic_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_topic_category.","type":"array","items":{"type":"integer"},"required":false},"ld_topic_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_topic_tag.","type":"array","items":{"type":"integer"},"required":false},"topic_materials":{"description":"Chapitre Documents","type":"html","required":false},"forced_lesson_time":{"default":"","description":"Forced Chapitre Timer","type":"text","required":false},"lesson_assignment_upload":{"default":0,"description":"Devoirs \u00e0 t\u00e9l\u00e9charger","type":"boolean","required":false},"auto_approve_assignment":{"default":"on","description":"Approuver Automatiquement les Devoirs","type":"boolean","required":false},"assignment_upload_limit_count":{"default":"1","description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_points_enabled":{"default":0,"description":"Donner des points pour le Devoir","type":"boolean","required":false},"lesson_assignment_points_amount":{"default":0,"description":"Donner les Nombre de Points pour le Devoir","type":"number","required":false},"assignment_upload_limit_extensions":{"default":"","description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"default":"","description":"Allowed File Size","type":"text","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v1\/sfwd-topic"}]}},"\/ldlms\/v1\/sfwd-topic\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe de ce post si il est prot\u00e9g\u00e9 par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"ld_topic_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_topic_category.","type":"array","items":{"type":"integer"},"required":false},"ld_topic_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_topic_tag.","type":"array","items":{"type":"integer"},"required":false},"topic_materials":{"description":"Chapitre Documents","type":"html","required":false},"forced_lesson_time":{"description":"Forced Chapitre Timer","type":"text","required":false},"lesson_assignment_upload":{"description":"Devoirs \u00e0 t\u00e9l\u00e9charger","type":"boolean","required":false},"auto_approve_assignment":{"description":"Approuver Automatiquement les Devoirs","type":"boolean","required":false},"assignment_upload_limit_count":{"description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_points_enabled":{"description":"Donner des points pour le Devoir","type":"boolean","required":false},"lesson_assignment_points_amount":{"description":"Donner les Nombre de Points pour le Devoir","type":"number","required":false},"assignment_upload_limit_extensions":{"description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"description":"Allowed File Size","type":"text","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}}]},"\/wp\/v2\/sfwd-quiz":{"namespace":"wp\/v2","methods":["GET","POST","GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":[]},{"methods":["POST"],"allow_batch":{"v1":true},"args":[]},{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"course":{"description":"Limit results to be within a specific Cours. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Le\u00e7on. Pass zero to show global Cours Quiz. Must be used with Cours parameter.","type":"integer","required":false},"topic":{"description":"Limit results to be within a specific Chapitre. Must be used with Cours parameter.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"quiz_materials":{"description":"Quiz Documents","type":"html","required":false},"threshold":{"default":"0.8","description":"Seuil de certificat","type":"text","required":false},"passingpercentage":{"default":"80","description":"Pourcentage de passage","type":"text","required":false},"certificate":{"default":"","description":"Certificat associ\u00e9","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/sfwd-quiz"}]}},"\/wp\/v2\/sfwd-quiz\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE","GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe de ce post si il est prot\u00e9g\u00e9 par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"quiz_materials":{"description":"Quiz Documents","type":"html","required":false},"threshold":{"description":"Seuil de certificat","type":"text","required":false},"passingpercentage":{"description":"Pourcentage de passage","type":"text","required":false},"certificate":{"description":"Certificat associ\u00e9","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}},{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"quiz_materials":{"description":"Quiz Documents","type":"html","required":false},"threshold":{"description":"Seuil de certificat","type":"text","required":false},"passingpercentage":{"description":"Pourcentage de passage","type":"text","required":false},"certificate":{"description":"Certificat associ\u00e9","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/ldlms\/v1\/sfwd-quiz":{"namespace":"ldlms\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"course":{"description":"Limit results to be within a specific Cours. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Le\u00e7on. Pass zero to show global Cours Quiz. Must be used with Cours parameter.","type":"integer","required":false},"topic":{"description":"Limit results to be within a specific Chapitre. Must be used with Cours parameter.","type":"integer","required":false}}},{"methods":["POST"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"quiz_materials":{"description":"Quiz Documents","type":"html","required":false},"threshold":{"default":"0.8","description":"Seuil de certificat","type":"text","required":false},"passingpercentage":{"default":"80","description":"Pourcentage de passage","type":"text","required":false},"certificate":{"default":"","description":"Certificat associ\u00e9","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v1\/sfwd-quiz"}]}},"\/ldlms\/v1\/sfwd-quiz\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the quiz object.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe de ce post si il est prot\u00e9g\u00e9 par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Unique identifier for the quiz object.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"quiz_materials":{"description":"Quiz Documents","type":"html","required":false},"threshold":{"description":"Seuil de certificat","type":"text","required":false},"passingpercentage":{"description":"Pourcentage de passage","type":"text","required":false},"certificate":{"description":"Certificat associ\u00e9","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the quiz object.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}}]},"\/ldlms\/v1\/groups":{"namespace":"ldlms\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"ld_group_category":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_group_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_group_category_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_group_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_group_tag":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_group_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_group_tag_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_group_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"ld_group_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_category.","type":"array","items":{"type":"integer"},"required":false},"ld_group_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_tag.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v1\/groups"}]}},"\/ldlms\/v1\/groups\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe de ce post si il est prot\u00e9g\u00e9 par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":true},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"ld_group_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_category.","type":"array","items":{"type":"integer"},"required":false},"ld_group_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_tag.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour cet objet.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}}]},"\/ldlms\/v1\/groups\/(?P<id>[\\d]+)\/courses":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Groupe ID to enroll into.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"fields":{"description":"Returned values.","type":"string","default":"ids","enum":["ids","objects"],"required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Groupe ID to enroll into.","type":"integer","required":true},"course_ids":{"description":"Cours IDs to enroll into groupe.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Groupe ID to enroll into.","type":"integer","required":true},"course_ids":{"description":"Cours IDs to remove from groupe.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v1\/groups\/(?P<id>[\\d]+)\/leaders":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"groupe ID to enroll leader du groupe into.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"fields":{"description":"Returned values.","type":"string","default":"ids","enum":["ids","objects"],"required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"default":"asc","description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","enum":["asc","desc"],"type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"roles":{"description":"Limiter le r\u00e9sultat aux comptes correspondants \u00e0 au moins un r\u00f4le sp\u00e9cifique fourni. Accepte les listes de type CSV ou les r\u00f4les uniques.","type":"array","items":{"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux comptes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"groupe ID to enroll leader du groupe into.","type":"integer","required":true},"user_ids":{"description":"Leader du Groupe User IDs to enroll into Groupe","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"groupe ID to enroll leader du groupe into.","type":"integer","required":true},"user_ids":{"description":"Leader du Groupe User IDs to remove from Groupe","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v1\/groups\/(?P<id>[\\d]+)\/users":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"groupe ID to enroll leader du groupe into.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"fields":{"description":"Returned values.","type":"string","default":"ids","enum":["ids","objects"],"required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"default":"asc","description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","enum":["asc","desc"],"type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"roles":{"description":"Limiter le r\u00e9sultat aux comptes correspondants \u00e0 au moins un r\u00f4le sp\u00e9cifique fourni. Accepte les listes de type CSV ou les r\u00f4les uniques.","type":"array","items":{"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux comptes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"groupe ID to enroll leader du groupe into.","type":"integer","required":true},"user_ids":{"description":"User IDs to enroll into Group.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"groupe ID to enroll leader du groupe into.","type":"integer","required":true},"user_ids":{"description":"User IDs to remove from Group.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v1\/users\/(?P<id>[\\d]+)\/groups":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID de l&#039;utilisateur","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"fields":{"description":"Returned values.","type":"string","default":"ids","enum":["ids","objects"],"required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID de l&#039;utilisateur","type":"integer","required":true},"group_ids":{"description":"Groupe IDs to add to User.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"ID de l&#039;utilisateur","type":"integer","required":true},"group_ids":{"description":"Groupe IDs to remove from User.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v1\/users\/(?P<id>[\\d]+)\/courses":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"User ID to enroll user into.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"fields":{"description":"Returned values.","type":"string","default":"ids","enum":["ids","objects"],"required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"User ID to enroll user into.","type":"integer","required":true},"course_ids":{"description":"Cours IDs to add to User.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"User ID to enroll user into.","type":"integer","required":true},"course_ids":{"description":"Cours IDs to remove from User.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v1\/sfwd-questions":{"namespace":"ldlms\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v1\/sfwd-questions"}]}},"\/ldlms\/v1\/sfwd-questions\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"The question ID","required":true}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"The question ID","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"The question ID","required":true}}}]},"\/ldlms\/v1\/sections\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v1","methods":["POST","PUT","PATCH"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"id":{"required":true}}}]},"\/ldlms\/v2":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"ldlms\/v2","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v2"}]}},"\/ldlms\/v2\/sfwd-courses":{"namespace":"ldlms\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"materials_enabled":{"default":false,"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Documents","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"certificate":{"default":0,"description":"Cours Certificate","type":"integer","required":false},"exam_challenge":{"default":0,"description":"Challenge Exam Show","type":"integer","required":false},"disable_content_table":{"default":false,"description":"Disable Cours Content Table","type":"boolean","required":false},"lessons_per_page":{"default":false,"description":"Custom Pagination","type":"boolean","required":false},"lesson_per_page_custom":{"default":0,"description":"Le\u00e7ons per page","type":"integer","required":false},"topic_per_page_custom":{"default":0,"description":"Le\u00e7ons per page","type":"integer","required":false},"price_type":{"default":"open","description":"Cours Price Type","type":"string","enum":["open","closed","free","paynow","subscribe"],"required":false},"price_type_paynow_price":{"default":"","description":"Pay Now Cours Price","type":"string","required":false},"price_type_paynow_enrollment_url":{"default":"","description":"Pay Now cours Enrollment URL","type":"string","required":false},"price_type_subscribe_price":{"default":"","description":"Subscribe Cours Price","type":"string","required":false},"trial_price":{"default":"","description":"Cours Trial Price","type":"string","required":false},"price_type_subscribe_enrollment_url":{"default":"","description":"Subscribe cours Enrollment URL","type":"string","required":false},"price_type_closed_price":{"default":"","description":"Closed Cours Price","type":"string","required":false},"price_type_closed_custom_button_url":{"default":"","description":"Closed Cours Button URL","type":"string","required":false},"prerequisite_enabled":{"default":false,"description":"Cours Prerequisites","type":"boolean","required":false},"prerequisite_compare":{"default":"ANY","description":"Prerequisite Compare Mode.","type":"string","enum":["ANY","ALL"],"required":false},"prerequisites":{"default":[],"description":"Prerequisites.","type":"array","items":{"type":"integer"},"required":false},"points_enabled":{"default":false,"description":"Cours Points","type":"boolean","required":false},"points_access":{"default":0,"description":"Required for Access","type":"float","required":false},"points_amount":{"default":0,"description":"Awarded on Completion","type":"float","required":false},"expire_access":{"default":false,"description":"Cours Access Expiration","type":"boolean","required":false},"expire_access_days":{"description":"Access Period","type":"integer","required":false},"expire_access_delete_progress":{"default":false,"description":"Data Deletion","type":"boolean","required":false},"progression_disabled":{"default":false,"description":"Cours Progression Disabled","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v2\/sfwd-courses"}]}},"\/ldlms\/v2\/sfwd-courses\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"materials_enabled":{"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Documents","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"certificate":{"description":"Cours Certificate","type":"integer","required":false},"exam_challenge":{"description":"Challenge Exam Show","type":"integer","required":false},"disable_content_table":{"description":"Disable Cours Content Table","type":"boolean","required":false},"lessons_per_page":{"description":"Custom Pagination","type":"boolean","required":false},"lesson_per_page_custom":{"description":"Le\u00e7ons per page","type":"integer","required":false},"topic_per_page_custom":{"description":"Le\u00e7ons per page","type":"integer","required":false},"price_type":{"description":"Cours Price Type","type":"string","enum":["open","closed","free","paynow","subscribe"],"required":false},"price_type_paynow_price":{"description":"Pay Now Cours Price","type":"string","required":false},"price_type_paynow_enrollment_url":{"description":"Pay Now cours Enrollment URL","type":"string","required":false},"price_type_subscribe_price":{"description":"Subscribe Cours Price","type":"string","required":false},"trial_price":{"description":"Cours Trial Price","type":"string","required":false},"price_type_subscribe_enrollment_url":{"description":"Subscribe cours Enrollment URL","type":"string","required":false},"price_type_closed_price":{"description":"Closed Cours Price","type":"string","required":false},"price_type_closed_custom_button_url":{"description":"Closed Cours Button URL","type":"string","required":false},"prerequisite_enabled":{"description":"Cours Prerequisites","type":"boolean","required":false},"prerequisite_compare":{"description":"Prerequisite Compare Mode.","type":"string","enum":["ANY","ALL"],"required":false},"prerequisites":{"description":"Prerequisites.","type":"array","items":{"type":"integer"},"required":false},"points_enabled":{"description":"Cours Points","type":"boolean","required":false},"points_access":{"description":"Required for Access","type":"float","required":false},"points_amount":{"description":"Awarded on Completion","type":"float","required":false},"expire_access":{"description":"Cours Access Expiration","type":"boolean","required":false},"expire_access_days":{"description":"Access Period","type":"integer","required":false},"expire_access_delete_progress":{"description":"Data Deletion","type":"boolean","required":false},"progression_disabled":{"description":"Cours Progression Disabled","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}}]},"\/ldlms\/v2\/sfwd-courses\/(?P<id>[\\d]+)\/steps":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Cours ID","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Filter returned results by step type.","type":"string","default":"all","enum":["all","h","l","t","r","co","sections","legacy"],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Cours ID","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Filter returned results by step type.","type":"string","default":"all","enum":["all","h","l","t","r","co","sections","legacy"],"required":false}}}]},"\/ldlms\/v2\/sfwd-courses\/(?P<id>[\\d]+)\/prerequisites":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Cours ID","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}}]},"\/ldlms\/v2\/sfwd-courses\/(?P<id>[\\d]+)\/users":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Cours ID.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"default":"asc","description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Trier la collection par attributs de compte.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux comptes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Limiter le r\u00e9sultat aux comptes correspondants \u00e0 au moins un r\u00f4le sp\u00e9cifique fourni. Accepte les listes de type CSV ou les r\u00f4les uniques.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Limiter le jeu de r\u00e9sultats aux comptes correspondant \u00e0 au moins une capacit\u00e9 sp\u00e9cifique fournie. Accepte une liste CSV ou une capacit\u00e9 unique.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Limiter le jeu de r\u00e9sultats aux comptes consid\u00e9r\u00e9s comme auteurs ou autrices.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Limiter les r\u00e9sultats aux comptes qui ont mis en ligne des publications.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","sfwd-courses":"sfwd-courses","sfwd-lessons":"sfwd-lessons","sfwd-topic":"sfwd-topic","sfwd-quiz":"sfwd-quiz","sfwd-question":"sfwd-question","ld-exam":"ld-exam","groups":"groups","sfwd-essays":"sfwd-essays","sfwd-assignment":"sfwd-assignment"}},"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Cours ID.","type":"integer","required":true},"user_ids":{"description":"User IDs to update in Course. Limit 50 per request.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Cours ID.","type":"integer","required":true},"user_ids":{"description":"User IDs to remove from Course. Limit 50 per request.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v2\/sfwd-courses\/(?P<id>[\\d]+)\/groups":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Cours ID","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"ld_group_category":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_group_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_group_category_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_group_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_group_tag":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_group_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_group_tag_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_group_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Cours ID","type":"integer","required":true},"group_ids":{"description":"Groupe IDs to enroll into Cours.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Cours ID","type":"integer","required":true},"group_ids":{"description":"Groupe IDs to remove from Cours.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v2\/sfwd-lessons":{"namespace":"ldlms\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"course":{"description":"Limit results to be within a specific Cours. Required for non-admin users.","type":"integer","required":false}}},{"methods":["POST"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"materials_enabled":{"default":false,"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Documents","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"video_enabled":{"default":false,"description":"Le\u00e7on Video Progression Enabled","type":"boolean","required":false},"video_url":{"default":"","description":"Le\u00e7on Video Progression URL","type":"text","required":false},"video_shown":{"default":"BEFORE","description":"Le\u00e7on Video Shown before or after sub-steps","type":"string","enum":["BEFORE","AFTER"],"required":false},"video_auto_complete":{"default":false,"description":"Le\u00e7on Video Auto-complete","type":"boolean","required":false},"video_auto_complete_delay":{"default":0,"description":"Le\u00e7on Video Completion Delay (seconds).","type":"integer","required":false},"video_show_complete_button":{"default":false,"description":"Le\u00e7on Video Show Mark Complete Button","type":"boolean","required":false},"video_auto_start":{"default":false,"description":"Le\u00e7on Video Autostart","type":"boolean","required":false},"video_show_controls":{"default":false,"description":"Le\u00e7on Video Controls Display. YouTube and local videos only","type":"boolean","required":false},"video_focus_pause":{"default":false,"description":"Video Pause on Window Unfocused","type":"boolean","required":false},"video_resume":{"default":false,"description":"Video Resume","type":"boolean","required":false},"assignment_upload_enabled":{"default":false,"description":"Le\u00e7on Assignment Uploads Enabled","type":"boolean","required":false},"assignment_upload_limit_extensions":{"default":"","description":"Le\u00e7on Assignment Allowed file extensions. Comma separated pdf, xls, zip","type":"text","required":false},"assignment_upload_limit_size":{"default":"","description":"Le\u00e7on Assignment Upload size limit. Max per server is 256M ","type":"text","required":false},"assignment_points_enabled":{"default":false,"description":"Le\u00e7on Assignment Points Enabled","type":"boolean","required":false},"assignment_points_amount":{"default":0,"description":"Le\u00e7on Assignment Points Amount","type":"integer","required":false},"assignment_auto_approve":{"default":true,"description":"Le\u00e7on Assignment Auto-approve Enabled","type":"boolean","required":false},"assignment_upload_limit_count":{"default":0,"description":"Le\u00e7on Assignment Upload Count Limit.","type":"integer","required":false},"assignment_deletion_enabled":{"default":false,"description":"Le\u00e7on Assignment Allow File Deletion.","type":"boolean","required":false},"forced_timer_enabled":{"default":false,"description":"Le\u00e7on Time Enabled","type":"boolean","required":false},"forced_timer_amount":{"default":0,"description":"Le\u00e7on Timer Amount.","type":"integer","required":false},"course":{"default":0,"description":"Associated Cours","type":"integer","required":false},"is_sample":{"default":false,"description":"Le\u00e7on d&#039;essai","type":"boolean","required":false},"visible_type":{"default":"","description":"Available Release Schedule","type":"string","enum":["","visible_after","visible_after_specific_date"],"required":false},"visible_after":{"default":0,"description":"Visible After X day(s)","type":"integer","required":false},"visible_after_specific_date":{"default":"","description":"Visible After Specific Date (YYYY-MM-DD)","type":"date","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v2\/sfwd-lessons"}]}},"\/ldlms\/v2\/sfwd-lessons\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"course":{"description":"Limit results to be within a specific Cours. Required for non-admin users.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"materials_enabled":{"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Documents","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"video_enabled":{"description":"Le\u00e7on Video Progression Enabled","type":"boolean","required":false},"video_url":{"description":"Le\u00e7on Video Progression URL","type":"text","required":false},"video_shown":{"description":"Le\u00e7on Video Shown before or after sub-steps","type":"string","enum":["BEFORE","AFTER"],"required":false},"video_auto_complete":{"description":"Le\u00e7on Video Auto-complete","type":"boolean","required":false},"video_auto_complete_delay":{"description":"Le\u00e7on Video Completion Delay (seconds).","type":"integer","required":false},"video_show_complete_button":{"description":"Le\u00e7on Video Show Mark Complete Button","type":"boolean","required":false},"video_auto_start":{"description":"Le\u00e7on Video Autostart","type":"boolean","required":false},"video_show_controls":{"description":"Le\u00e7on Video Controls Display. YouTube and local videos only","type":"boolean","required":false},"video_focus_pause":{"description":"Video Pause on Window Unfocused","type":"boolean","required":false},"video_resume":{"description":"Video Resume","type":"boolean","required":false},"assignment_upload_enabled":{"description":"Le\u00e7on Assignment Uploads Enabled","type":"boolean","required":false},"assignment_upload_limit_extensions":{"description":"Le\u00e7on Assignment Allowed file extensions. Comma separated pdf, xls, zip","type":"text","required":false},"assignment_upload_limit_size":{"description":"Le\u00e7on Assignment Upload size limit. Max per server is 256M ","type":"text","required":false},"assignment_points_enabled":{"description":"Le\u00e7on Assignment Points Enabled","type":"boolean","required":false},"assignment_points_amount":{"description":"Le\u00e7on Assignment Points Amount","type":"integer","required":false},"assignment_auto_approve":{"description":"Le\u00e7on Assignment Auto-approve Enabled","type":"boolean","required":false},"assignment_upload_limit_count":{"description":"Le\u00e7on Assignment Upload Count Limit.","type":"integer","required":false},"assignment_deletion_enabled":{"description":"Le\u00e7on Assignment Allow File Deletion.","type":"boolean","required":false},"forced_timer_enabled":{"description":"Le\u00e7on Time Enabled","type":"boolean","required":false},"forced_timer_amount":{"description":"Le\u00e7on Timer Amount.","type":"integer","required":false},"course":{"description":"Associated Cours","type":"integer","required":false},"is_sample":{"description":"Le\u00e7on d&#039;essai","type":"boolean","required":false},"visible_type":{"description":"Available Release Schedule","type":"string","enum":["","visible_after","visible_after_specific_date"],"required":false},"visible_after":{"description":"Visible After X day(s)","type":"integer","required":false},"visible_after_specific_date":{"description":"Visible After Specific Date (YYYY-MM-DD)","type":"date","required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}}]},"\/ldlms\/v2\/sfwd-topic":{"namespace":"ldlms\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"ld_topic_category":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_topic_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_topic_category_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_topic_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_topic_tag":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_topic_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_topic_tag_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_topic_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"course":{"description":"Limit results to be within a specific Cours. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Le\u00e7on. Must be used with Cours parameter.","type":"integer","required":false}}},{"methods":["POST"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"ld_topic_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_topic_category.","type":"array","items":{"type":"integer"},"required":false},"ld_topic_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_topic_tag.","type":"array","items":{"type":"integer"},"required":false},"materials_enabled":{"default":false,"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Documents","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"video_enabled":{"default":false,"description":"Chapitre Video Progression Enabled","type":"boolean","required":false},"video_url":{"default":"","description":"Chapitre Video Progression URL","type":"text","required":false},"video_shown":{"default":"BEFORE","description":"Chapitre Video Shown before or after sub-steps","type":"string","enum":["BEFORE","AFTER"],"required":false},"video_auto_complete":{"default":false,"description":"Chapitre Video Auto-complete","type":"boolean","required":false},"video_auto_complete_delay":{"default":0,"description":"Chapitre Video Completion Delay (seconds).","type":"integer","required":false},"video_show_complete_button":{"default":false,"description":"Chapitre Video Show Mark Complete Button","type":"boolean","required":false},"video_auto_start":{"default":false,"description":"Chapitre Video Autostart","type":"boolean","required":false},"video_show_controls":{"default":false,"description":"Chapitre Video Controls Display. YouTube and local videos only","type":"boolean","required":false},"video_focus_pause":{"default":false,"description":"Video Pause on Window Unfocused","type":"boolean","required":false},"video_resume":{"default":false,"description":"Video Resume","type":"boolean","required":false},"assignment_upload_enabled":{"default":false,"description":"Chapitre Assignment Uploads Enabled","type":"boolean","required":false},"assignment_upload_limit_extensions":{"default":"","description":"Chapitre Assignment Allowed file extensions. Comma separated pdf, xls, zip","type":"text","required":false},"assignment_upload_limit_size":{"default":"","description":"Chapitre Assignment Upload size limit. Max per server is 256M ","type":"text","required":false},"assignment_points_enabled":{"default":false,"description":"Chapitre Assignment Points Enabled","type":"boolean","required":false},"assignment_points_amount":{"default":0,"description":"Chapitre Assignment Points Amount","type":"integer","required":false},"assignment_auto_approve":{"default":true,"description":"Chapitre Assignment Auto-approve Enabled","type":"boolean","required":false},"assignment_upload_limit_count":{"default":0,"description":"Chapitre Assignment Upload Count Limit.","type":"integer","required":false},"assignment_deletion_enabled":{"default":false,"description":"Chapitre Assignment Allow File Deletion.","type":"boolean","required":false},"forced_timer_enabled":{"default":false,"description":"Chapitre Time Enabled","type":"boolean","required":false},"forced_timer_amount":{"default":0,"description":"Chapitre Timer Amount.","type":"integer","required":false},"course":{"default":0,"description":"Cours associ\u00e9","type":"integer","required":false},"lesson":{"default":0,"description":"Associated Le\u00e7on","type":"integer","required":false},"visible_type":{"default":"","description":"Available Release Schedule","type":"string","enum":["","visible_after","visible_after_specific_date"],"required":false},"visible_after":{"default":0,"description":"Visible After X day(s)","type":"integer","required":false},"visible_after_specific_date":{"default":"","description":"Visible After Specific Date (YYYY-MM-DD)","type":"date","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v2\/sfwd-topic"}]}},"\/ldlms\/v2\/sfwd-topic\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"ld_topic_category":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_topic_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_topic_category_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_topic_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_topic_tag":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_topic_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_topic_tag_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_topic_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"course":{"description":"Limit results to be within a specific Cours. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Le\u00e7on. Must be used with Cours parameter.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"ld_topic_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_topic_category.","type":"array","items":{"type":"integer"},"required":false},"ld_topic_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_topic_tag.","type":"array","items":{"type":"integer"},"required":false},"materials_enabled":{"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Documents","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"video_enabled":{"description":"Chapitre Video Progression Enabled","type":"boolean","required":false},"video_url":{"description":"Chapitre Video Progression URL","type":"text","required":false},"video_shown":{"description":"Chapitre Video Shown before or after sub-steps","type":"string","enum":["BEFORE","AFTER"],"required":false},"video_auto_complete":{"description":"Chapitre Video Auto-complete","type":"boolean","required":false},"video_auto_complete_delay":{"description":"Chapitre Video Completion Delay (seconds).","type":"integer","required":false},"video_show_complete_button":{"description":"Chapitre Video Show Mark Complete Button","type":"boolean","required":false},"video_auto_start":{"description":"Chapitre Video Autostart","type":"boolean","required":false},"video_show_controls":{"description":"Chapitre Video Controls Display. YouTube and local videos only","type":"boolean","required":false},"video_focus_pause":{"description":"Video Pause on Window Unfocused","type":"boolean","required":false},"video_resume":{"description":"Video Resume","type":"boolean","required":false},"assignment_upload_enabled":{"description":"Chapitre Assignment Uploads Enabled","type":"boolean","required":false},"assignment_upload_limit_extensions":{"description":"Chapitre Assignment Allowed file extensions. Comma separated pdf, xls, zip","type":"text","required":false},"assignment_upload_limit_size":{"description":"Chapitre Assignment Upload size limit. Max per server is 256M ","type":"text","required":false},"assignment_points_enabled":{"description":"Chapitre Assignment Points Enabled","type":"boolean","required":false},"assignment_points_amount":{"description":"Chapitre Assignment Points Amount","type":"integer","required":false},"assignment_auto_approve":{"description":"Chapitre Assignment Auto-approve Enabled","type":"boolean","required":false},"assignment_upload_limit_count":{"description":"Chapitre Assignment Upload Count Limit.","type":"integer","required":false},"assignment_deletion_enabled":{"description":"Chapitre Assignment Allow File Deletion.","type":"boolean","required":false},"forced_timer_enabled":{"description":"Chapitre Time Enabled","type":"boolean","required":false},"forced_timer_amount":{"description":"Chapitre Timer Amount.","type":"integer","required":false},"course":{"description":"Cours associ\u00e9","type":"integer","required":false},"lesson":{"description":"Associated Le\u00e7on","type":"integer","required":false},"visible_type":{"description":"Available Release Schedule","type":"string","enum":["","visible_after","visible_after_specific_date"],"required":false},"visible_after":{"description":"Visible After X day(s)","type":"integer","required":false},"visible_after_specific_date":{"description":"Visible After Specific Date (YYYY-MM-DD)","type":"date","required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}}]},"\/ldlms\/v2\/sfwd-quiz":{"namespace":"ldlms\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"course":{"description":"Limit results to be within a specific Cours. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Le\u00e7on. Pass zero to show global Cours Quiz. Must be used with Cours parameter.","type":"integer","required":false},"topic":{"description":"Limit results to be within a specific Chapitre. Must be used with Cours parameter.","type":"integer","required":false}}},{"methods":["POST"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"course":{"default":0,"description":"Associated Cours","type":"integer","required":false},"lesson":{"default":0,"description":"Associated Le\u00e7on","type":"integer","required":false},"visible_type":{"default":"","description":"Available Release Schedule","type":"string","enum":["","visible_after","visible_after_specific_date"],"required":false},"visible_after":{"default":0,"description":"Visible After X day(s)","type":"integer","required":false},"visible_after_specific_date":{"default":"","description":"Visible After Specific Date (YYYY-MM-DD)","type":"date","required":false},"prerequisites":{"default":[],"description":"Quiz Prerequisites","type":"array","items":{"type":"integer"},"required":false},"registered_users_only":{"default":false,"description":"Allowed Users","type":"boolean","required":false},"passing_percentage":{"default":0,"description":"Passing Score Percentage","type":"float","required":false},"certificate":{"default":0,"description":"Quiz Certificate","type":"integer","required":false},"certificate_award_threshold":{"default":0,"description":"Certificate Awarded for","type":"float","required":false},"quiz_resume":{"default":false,"description":"Enable Quiz Saving","type":"boolean","required":false},"quiz_resume_cookie_send_timer":{"default":20,"description":"Save cookie data to the server every","type":"integer","required":false},"retry_restrictions_enabled":{"default":false,"description":"Restrict Quiz Retakes","type":"boolean","required":false},"retry_repeats":{"default":"","description":"Number of repeats allowed. blank is unlimited, 0 is 1 repeats, 1 is 2 repeats, etc.","type":"string","required":false},"answer_all_questions_enabled":{"default":true,"description":"All Questions required to complete","type":"boolean","required":false},"time_limit_enabled":{"default":false,"description":"Time Limit Enabled","type":"boolean","required":false},"time_limit_time":{"default":0,"description":"Automatically Submit After","type":"integer","required":false},"materials_enabled":{"default":false,"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Documents","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"auto_start":{"default":false,"description":"Autostart","type":"boolean","required":false},"quiz_modus":{"default":"single","description":"Question Display","type":"string","enum":["single","multiple"],"required":false},"review_table_enabled":{"default":false,"description":"Question Overview Table","type":"boolean","required":false},"summary_hide":{"default":false,"description":"Quiz Summary","type":"boolean","required":false},"skip_question_disabled":{"default":false,"description":"Skip Question","type":"boolean","required":false},"custom_sorting":{"default":false,"description":"Custom Question Ordering","type":"boolean","required":false},"sort_categories":{"default":false,"description":"Sort by Category","type":"boolean","required":false},"question_random":{"default":false,"description":"Randomize Order","type":"boolean","required":false},"show_max_question":{"default":false,"description":"","type":"boolean","required":false},"show_points":{"default":false,"description":"Point Value","type":"boolean","required":false},"show_category":{"default":false,"description":"Question Category","type":"boolean","required":false},"hide_question_position_overview":{"default":false,"description":"Question Position","type":"boolean","required":false},"hide_question_numbering":{"default":false,"description":"Question Numbering","type":"boolean","required":false},"numbered_answer":{"default":false,"description":"Number Answers","type":"boolean","required":false},"answer_random":{"default":false,"description":"Randomize Answers","type":"boolean","required":false},"title_hidden":{"default":false,"description":"Quiz Titre","type":"boolean","required":false},"restart_button_hide":{"default":true,"description":"Restart Quiz button","type":"boolean","required":false},"show_average_result":{"default":true,"description":"Average Score","type":"boolean","required":false},"show_category_score":{"default":true,"description":"Category Score","type":"boolean","required":false},"hide_result_points":{"default":true,"description":"Overall Score","type":"boolean","required":false},"hide_result_correct_question":{"default":true,"description":"No. of Correct Answers","type":"boolean","required":false},"hide_result_quiz_time":{"default":true,"description":"Temps pass\u00e9","type":"boolean","required":false},"custom_answer_feedback":{"default":true,"description":"Custom Answer Feedback","type":"boolean","required":false},"hide_answer_message_box":{"default":true,"description":"Correct \/ Incorrect Messages","type":"boolean","required":false},"disabled_answer_mark":{"default":true,"description":"Correct \/ Incorrect Answer Marks","type":"boolean","required":false},"view_question_button_hidden":{"default":true,"description":"View Questions Button","type":"boolean","required":false},"toplist_enabled":{"default":false,"description":"Podium","type":"boolean","required":false},"toplist_data_add_permissions":{"default":"1","description":"Who can apply?","type":"string","enum":["1","2","3"],"required":false},"toplist_data_add_multiple":{"default":false,"description":"Multiple Applications per user","type":"boolean","required":false},"toplist_data_add_automatic":{"default":false,"description":"Automatic user entry","type":"boolean","required":false},"toplist_data_show_limit":{"default":10,"description":"Number of displayed entries","type":"integer","required":false},"toplist_data_sort":{"default":"1","description":"Sort list by?","type":"string","enum":["1","2","3"],"required":false},"toplist_data_showin_enabled":{"default":false,"description":"Display on Quiz results page","type":"boolean","required":false},"statistics_enabled":{"default":true,"description":"Quiz Statistics","type":"boolean","required":false},"view_profile_statistics_enabled":{"default":true,"description":"Front-end Profile Display","type":"boolean","required":false},"statistics_ip_lock_enabled":{"default":false,"description":"Blocage des statistiques par IP","type":"boolean","required":false},"email_enabled":{"default":false,"description":"Email Notifications","type":"boolean","required":false},"email_admin_enabled":{"default":false,"description":"Admin","type":"boolean","required":false},"email_user_enabled":{"default":false,"description":"Utilisateur","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v2\/sfwd-quiz"}]}},"\/ldlms\/v2\/sfwd-quiz\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"course":{"description":"Limit results to be within a specific Cours. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Le\u00e7on. Pass zero to show global Cours Quiz. Must be used with Cours parameter.","type":"integer","required":false},"topic":{"description":"Limit results to be within a specific Chapitre. Must be used with Cours parameter.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"course":{"description":"Associated Cours","type":"integer","required":false},"lesson":{"description":"Associated Le\u00e7on","type":"integer","required":false},"visible_type":{"description":"Available Release Schedule","type":"string","enum":["","visible_after","visible_after_specific_date"],"required":false},"visible_after":{"description":"Visible After X day(s)","type":"integer","required":false},"visible_after_specific_date":{"description":"Visible After Specific Date (YYYY-MM-DD)","type":"date","required":false},"prerequisites":{"description":"Quiz Prerequisites","type":"array","items":{"type":"integer"},"required":false},"registered_users_only":{"description":"Allowed Users","type":"boolean","required":false},"passing_percentage":{"description":"Passing Score Percentage","type":"float","required":false},"certificate":{"description":"Quiz Certificate","type":"integer","required":false},"certificate_award_threshold":{"description":"Certificate Awarded for","type":"float","required":false},"quiz_resume":{"description":"Enable Quiz Saving","type":"boolean","required":false},"quiz_resume_cookie_send_timer":{"description":"Save cookie data to the server every","type":"integer","required":false},"retry_restrictions_enabled":{"description":"Restrict Quiz Retakes","type":"boolean","required":false},"retry_repeats":{"description":"Number of repeats allowed. blank is unlimited, 0 is 1 repeats, 1 is 2 repeats, etc.","type":"string","required":false},"answer_all_questions_enabled":{"description":"All Questions required to complete","type":"boolean","required":false},"time_limit_enabled":{"description":"Time Limit Enabled","type":"boolean","required":false},"time_limit_time":{"description":"Automatically Submit After","type":"integer","required":false},"materials_enabled":{"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Documents","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"auto_start":{"description":"Autostart","type":"boolean","required":false},"quiz_modus":{"description":"Question Display","type":"string","enum":["single","multiple"],"required":false},"review_table_enabled":{"description":"Question Overview Table","type":"boolean","required":false},"summary_hide":{"description":"Quiz Summary","type":"boolean","required":false},"skip_question_disabled":{"description":"Skip Question","type":"boolean","required":false},"custom_sorting":{"description":"Custom Question Ordering","type":"boolean","required":false},"sort_categories":{"description":"Sort by Category","type":"boolean","required":false},"question_random":{"description":"Randomize Order","type":"boolean","required":false},"show_max_question":{"description":"","type":"boolean","required":false},"show_points":{"description":"Point Value","type":"boolean","required":false},"show_category":{"description":"Question Category","type":"boolean","required":false},"hide_question_position_overview":{"description":"Question Position","type":"boolean","required":false},"hide_question_numbering":{"description":"Question Numbering","type":"boolean","required":false},"numbered_answer":{"description":"Number Answers","type":"boolean","required":false},"answer_random":{"description":"Randomize Answers","type":"boolean","required":false},"title_hidden":{"description":"Quiz Titre","type":"boolean","required":false},"restart_button_hide":{"description":"Restart Quiz button","type":"boolean","required":false},"show_average_result":{"description":"Average Score","type":"boolean","required":false},"show_category_score":{"description":"Category Score","type":"boolean","required":false},"hide_result_points":{"description":"Overall Score","type":"boolean","required":false},"hide_result_correct_question":{"description":"No. of Correct Answers","type":"boolean","required":false},"hide_result_quiz_time":{"description":"Temps pass\u00e9","type":"boolean","required":false},"custom_answer_feedback":{"description":"Custom Answer Feedback","type":"boolean","required":false},"hide_answer_message_box":{"description":"Correct \/ Incorrect Messages","type":"boolean","required":false},"disabled_answer_mark":{"description":"Correct \/ Incorrect Answer Marks","type":"boolean","required":false},"view_question_button_hidden":{"description":"View Questions Button","type":"boolean","required":false},"toplist_enabled":{"description":"Podium","type":"boolean","required":false},"toplist_data_add_permissions":{"description":"Who can apply?","type":"string","enum":["1","2","3"],"required":false},"toplist_data_add_multiple":{"description":"Multiple Applications per user","type":"boolean","required":false},"toplist_data_add_automatic":{"description":"Automatic user entry","type":"boolean","required":false},"toplist_data_show_limit":{"description":"Number of displayed entries","type":"integer","required":false},"toplist_data_sort":{"description":"Sort list by?","type":"string","enum":["1","2","3"],"required":false},"toplist_data_showin_enabled":{"description":"Display on Quiz results page","type":"boolean","required":false},"statistics_enabled":{"description":"Quiz Statistics","type":"boolean","required":false},"view_profile_statistics_enabled":{"description":"Front-end Profile Display","type":"boolean","required":false},"statistics_ip_lock_enabled":{"description":"Blocage des statistiques par IP","type":"boolean","required":false},"email_enabled":{"description":"Email Notifications","type":"boolean","required":false},"email_admin_enabled":{"description":"Admin","type":"boolean","required":false},"email_user_enabled":{"description":"Utilisateur","type":"boolean","required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}}]},"\/ldlms\/v2\/sfwd-essays":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["graded","not_graded"],"type":"string"},"required":false},"course":{"description":"Filter by Cours ID","type":"integer","required":false},"lesson":{"description":"Filter by Le\u00e7on ID","type":"integer","default":0,"required":false},"topic":{"description":"Filter by Chapitre ID","type":"integer","default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v2\/sfwd-essays"}]}},"\/ldlms\/v2\/sfwd-essays\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["graded","not_graded"],"type":"string"},"required":false},"course":{"description":"Filter by Cours ID","type":"integer","required":false},"lesson":{"description":"Filter by Le\u00e7on ID","type":"integer","default":0,"required":false},"topic":{"description":"Filter by Chapitre ID","type":"integer","default":0,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"course":{"description":"Cours ID","type":"integer","required":false},"lesson":{"description":"Le\u00e7on ID","type":"integer","required":false},"topic":{"description":"Chapitre ID","type":"integer","required":false},"points_max":{"description":"Essay Points Maximum","type":"integer","required":false},"points_awarded":{"description":"Essay Points Awarded","type":"integer","required":false}}}]},"\/ldlms\/v2\/sfwd-question":{"namespace":"ldlms\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"quiz":{"default":"","description":"Quiz ID.","type":"integer","required":false},"question_type":{"default":"single","description":"Question type.","type":"enum","enum":["single","multiple","free_answer","sort_answer","matrix_sort_answer","cloze_answer","assessment_answer","essay"],"required":false},"points_total":{"default":"","description":"Total Points amount","type":"integer","required":false},"points_per_answer":{"default":"","description":"Diff\u00e9rents points pour chaque r\u00e9ponse","type":"boolean","required":false},"points_show_in_message":{"default":"","description":"Show reached points in the correct\/incorrect message?","type":"boolean","required":false},"points_diff_modus":{"default":"","description":"Points diff\u00e9rents - mode 2 activ\u00e9","type":"boolean","required":false},"disable_correct":{"default":"","description":"Disable answer correct setting.","type":"boolean","required":false},"correct_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"incorrect_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"correct_same":{"default":"","description":"Activate hint for this Question.","type":"boolean","required":false},"hints_enabled":{"default":"","description":"Activate hint for this Question.","type":"boolean","required":false},"hints_message":{"description":"Hint message.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"answers":{"description":"Question answer sets.","type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v2\/sfwd-question"}]}},"\/ldlms\/v2\/sfwd-question\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"quiz":{"description":"Quiz ID.","type":"integer","required":false},"question_type":{"description":"Question type.","type":"enum","enum":["single","multiple","free_answer","sort_answer","matrix_sort_answer","cloze_answer","assessment_answer","essay"],"required":false},"points_total":{"description":"Total Points amount","type":"integer","required":false},"points_per_answer":{"description":"Diff\u00e9rents points pour chaque r\u00e9ponse","type":"boolean","required":false},"points_show_in_message":{"description":"Show reached points in the correct\/incorrect message?","type":"boolean","required":false},"points_diff_modus":{"description":"Points diff\u00e9rents - mode 2 activ\u00e9","type":"boolean","required":false},"disable_correct":{"description":"Disable answer correct setting.","type":"boolean","required":false},"correct_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"incorrect_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"correct_same":{"description":"Activate hint for this Question.","type":"boolean","required":false},"hints_enabled":{"description":"Activate hint for this Question.","type":"boolean","required":false},"hints_message":{"description":"Hint message.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"answers":{"description":"Question answer sets.","type":"object","required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}}]},"\/ldlms\/v2\/sfwd-assignment":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["graded","not_graded"],"type":"string"},"required":false},"course":{"description":"Filter by Cours ID","type":"integer","required":false},"lesson":{"description":"Filter by Le\u00e7on ID","type":"integer","default":0,"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v2\/sfwd-assignment"}]}},"\/ldlms\/v2\/sfwd-assignment\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["graded","not_graded"],"type":"string"},"required":false},"course":{"description":"Filter by Cours ID","type":"integer","required":false},"lesson":{"description":"Filter by Le\u00e7on ID","type":"integer","default":0,"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"course":{"description":"Cours ID","type":"integer","required":false},"lesson":{"description":"Le\u00e7on ID","type":"integer","required":false},"topic":{"description":"Chapitre ID","type":"integer","required":false},"approved_status":{"description":"Assignment Approved Status","type":"string","enum":["","approved","not_approved"],"required":false},"points_enabled":{"description":"Assignment Points Enabled","type":"boolean","required":false},"points_max":{"description":"Assignment Points Maximum","type":"integer","required":false},"points_awarded":{"description":"Assignment Points Awarded","type":"integer","required":false}}}]},"\/ldlms\/v2\/groups":{"namespace":"ldlms\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"ld_group_category":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_group_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_group_category_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_group_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_group_tag":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_group_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_group_tag_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_group_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"ld_group_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_category.","type":"array","items":{"type":"integer"},"required":false},"ld_group_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_tag.","type":"array","items":{"type":"integer"},"required":false},"materials_enabled":{"default":false,"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Documents","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"certificate":{"default":0,"description":"Groupe Certificate","type":"integer","required":false},"disable_content_table":{"default":false,"description":"Groupe Content","type":"boolean","required":false},"courses_per_page_custom":{"default":0,"description":"Cours per page","type":"integer","required":false},"courses_orderby":{"default":"","description":"Organiser par","type":"string","required":false},"courses_order":{"default":"","description":"Order Direction","type":"string","required":false},"price_type":{"default":"closed","description":"Groupe Price Type","type":"string","enum":["closed","free","paynow","subscribe"],"required":false},"price_type_paynow_price":{"default":"","description":"Pay Now Groupe Price","type":"string","required":false},"group_price_type_paynow_enrollment_url":{"default":"","description":"Pay Now groupe Enrollment URL","type":"string","required":false},"price_type_subscribe_price":{"default":"","description":"Subscribe Groupe Price","type":"string","required":false},"trial_price":{"default":"","description":"Groupe Trial Price","type":"string","required":false},"group_price_type_subscribe_enrollment_url":{"default":"","description":"Pay Now groupe Enrollment URL","type":"string","required":false},"price_type_closed_price":{"default":"","description":"Closed Groupe Price","type":"string","required":false},"price_type_closed_custom_button_url":{"default":"","description":"Closed Groupe Button URL","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v2\/groups"}]}},"\/ldlms\/v2\/groups\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"ld_group_category":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_group_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_group_category_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_group_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_group_tag":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_group_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_group_tag_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_group_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"ld_group_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_category.","type":"array","items":{"type":"integer"},"required":false},"ld_group_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_tag.","type":"array","items":{"type":"integer"},"required":false},"materials_enabled":{"description":"Materials Enabled","type":"boolean","required":false},"materials":{"description":"Documents","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"certificate":{"description":"Groupe Certificate","type":"integer","required":false},"disable_content_table":{"description":"Groupe Content","type":"boolean","required":false},"courses_per_page_custom":{"description":"Cours per page","type":"integer","required":false},"courses_orderby":{"description":"Organiser par","type":"string","required":false},"courses_order":{"description":"Order Direction","type":"string","required":false},"price_type":{"description":"Groupe Price Type","type":"string","enum":["closed","free","paynow","subscribe"],"required":false},"price_type_paynow_price":{"description":"Pay Now Groupe Price","type":"string","required":false},"group_price_type_paynow_enrollment_url":{"description":"Pay Now groupe Enrollment URL","type":"string","required":false},"price_type_subscribe_price":{"description":"Subscribe Groupe Price","type":"string","required":false},"trial_price":{"description":"Groupe Trial Price","type":"string","required":false},"group_price_type_subscribe_enrollment_url":{"description":"Pay Now groupe Enrollment URL","type":"string","required":false},"price_type_closed_price":{"description":"Closed Groupe Price","type":"string","required":false},"price_type_closed_custom_button_url":{"description":"Closed Groupe Button URL","type":"string","required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}}]},"\/ldlms\/v2\/groups\/(?P<id>[\\d]+)\/courses":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Groupe ID","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Groupe ID","type":"integer","required":true},"course_ids":{"description":"Cours IDs to add to Groupe.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Groupe ID","type":"integer","required":true},"course_ids":{"description":"Cours IDs to remove from Groupe.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v2\/groups\/(?P<id>[\\d]+)\/leaders":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Groupe ID","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"default":"asc","description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Trier la collection par attributs de compte.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux comptes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Limiter le r\u00e9sultat aux comptes correspondants \u00e0 au moins un r\u00f4le sp\u00e9cifique fourni. Accepte les listes de type CSV ou les r\u00f4les uniques.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Limiter le jeu de r\u00e9sultats aux comptes correspondant \u00e0 au moins une capacit\u00e9 sp\u00e9cifique fournie. Accepte une liste CSV ou une capacit\u00e9 unique.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Limiter le jeu de r\u00e9sultats aux comptes consid\u00e9r\u00e9s comme auteurs ou autrices.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Limiter les r\u00e9sultats aux comptes qui ont mis en ligne des publications.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","sfwd-courses":"sfwd-courses","sfwd-lessons":"sfwd-lessons","sfwd-topic":"sfwd-topic","sfwd-quiz":"sfwd-quiz","sfwd-question":"sfwd-question","ld-exam":"ld-exam","groups":"groups","sfwd-essays":"sfwd-essays","sfwd-assignment":"sfwd-assignment"}},"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Groupe ID","type":"integer","required":true},"user_ids":{"description":"Leader du Groupe User IDs to enroll into Groupe","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Groupe ID","type":"integer","required":true},"user_ids":{"description":"Leader du Groupe User IDs to remove from Groupe","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v2\/groups\/(?P<id>[\\d]+)\/users":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Groupe ID","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"default":"asc","description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Trier la collection par attributs de compte.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux comptes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Limiter le r\u00e9sultat aux comptes correspondants \u00e0 au moins un r\u00f4le sp\u00e9cifique fourni. Accepte les listes de type CSV ou les r\u00f4les uniques.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Limiter le jeu de r\u00e9sultats aux comptes correspondant \u00e0 au moins une capacit\u00e9 sp\u00e9cifique fournie. Accepte une liste CSV ou une capacit\u00e9 unique.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Limiter le jeu de r\u00e9sultats aux comptes consid\u00e9r\u00e9s comme auteurs ou autrices.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Limiter les r\u00e9sultats aux comptes qui ont mis en ligne des publications.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","sfwd-courses":"sfwd-courses","sfwd-lessons":"sfwd-lessons","sfwd-topic":"sfwd-topic","sfwd-quiz":"sfwd-quiz","sfwd-question":"sfwd-question","ld-exam":"ld-exam","groups":"groups","sfwd-essays":"sfwd-essays","sfwd-assignment":"sfwd-assignment"}},"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Groupe ID","type":"integer","required":true},"user_ids":{"description":"User IDs to enroll into Groupe.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Groupe ID","type":"integer","required":true},"user_ids":{"description":"User IDs to remove from Groupe.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v2\/users\/(?P<id>[\\d]+)\/courses":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID de l&#039;utilisateur","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID de l&#039;utilisateur","type":"integer","required":true},"course_ids":{"description":"Cours IDs to add to User.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"ID de l&#039;utilisateur","type":"integer","required":true},"course_ids":{"description":"Cours IDs to remove from User.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v2\/users\/(?P<id>[\\d]+)\/groups":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID de l&#039;utilisateur","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"title","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"ld_group_category":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_group_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_group_category_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_group_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"ld_group_tag":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie ld_group_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"ld_group_tag_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie ld_group_tag.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"ID de l&#039;utilisateur","type":"integer","required":true},"group_ids":{"description":"Groupe IDs to add to User.","type":"array","items":{"type":"integer"},"required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"ID de l&#039;utilisateur","type":"integer","required":true},"group_ids":{"description":"Groupe IDs to remove from User.","type":"array","items":{"type":"integer"},"required":true}}}]},"\/ldlms\/v2\/users\/(?P<id>[\\d]+)\/course-progress":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID de l&#039;utilisateur","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false}}}]},"\/ldlms\/v2\/users\/(?P<id>[\\d]+)\/course-progress\/(?P<course>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID de l&#039;utilisateur","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false}}}]},"\/ldlms\/v2\/users\/(?P<id>[\\d]+)\/course-progress\/(?P<course>[\\d]+)\/steps":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID de l&#039;utilisateur","type":"integer","required":true},"course":{"description":"Unique Cours identifier for the object.","type":"integer","required":true}}}]},"\/ldlms\/v2\/users\/(?P<id>[\\d]+)\/quiz-progress":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"ID de l&#039;utilisateur","type":"integer","required":true},"quiz":{"description":"Limit results to be within a specific Quiz. Required for non-admin users.","type":"integer","required":false},"course":{"description":"Limit results to be within a specific Cours. Required for non-admin users.","type":"integer","required":false},"lesson":{"description":"Limit results to be within a specific Le\u00e7on. Pass zero to show global Cours Quiz. Must be used with Cours parameter.","type":"integer","required":false},"topic":{"description":"Limit results to be within a specific Chapitre. Must be used with Cours parameter.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"orderby":{"default":"taken","enum":["taken","title","id","date"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false}}}]},"\/ldlms\/v2\/sfwd-quiz\/(?P<quiz>[\\d]+)\/statistics":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"quiz":{"description":"Filter by Quiz ID","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"order":{"description":"Order sort attribute ascending or descending.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Sort collection by object attribute.","type":"string","default":"date","enum":["date","id","quiz","user"],"required":false},"user":{"description":"Filter by User ID","type":"integer","required":false},"after":{"description":"Limit response items after a given ISO8601 compliant date.","type":"string","format":"date-time","required":false},"before":{"description":"Limit response to items before a given ISO8601 compliant date.","type":"string","format":"date-time","required":false}}}]},"\/ldlms\/v2\/sfwd-quiz\/(?P<quiz>[\\d]+)\/statistics\/(?P<statistic>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"quiz":{"description":"Unique Quiz identifier for the object.","type":"integer","required":true}}}]},"\/ldlms\/v2\/sfwd-quiz\/(?P<quiz>[\\d]+)\/statistics\/(?P<statistic>[\\d]+)\/questions":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"quiz":{"description":"Unique Quiz identifier for the object.","type":"integer","required":true},"statistic":{"description":"Unique Quiz Statistic identifier for the object.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}]},"\/ldlms\/v2\/sfwd-quiz\/(?P<quiz>[\\d]+)\/statistics\/(?P<statistic>[\\d]+)\/questions\/(?P<id>[\\w-]+)":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"quiz":{"description":"Unique Quiz identifier for the object.","type":"integer","required":true},"statistic":{"description":"Unique Quiz Statistic identifier for the object.","type":"integer","required":true},"id":{"description":"Unique Quiz Statistic Question identifier for the object.","type":"text","required":true}}}]},"\/ldlms\/v2\/sfwd-quiz\/(?P<quiz>[\\d]+)\/form-entries":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed"],"default":"view","required":false},"user":{"description":"ID de l'utilisateur","type":"integer","default":0,"required":false},"quiz":{"description":"Quiz ID","type":"integer","default":0,"required":false},"order":{"description":"Ordre ","type":"string","default":"DESC","enum":["ASC","DESC"],"required":false},"orderby":{"description":"Ordonner par","type":"string","default":"date","enum":["date"],"required":false}}}]},"\/ldlms\/v2\/echo":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":[]},{"methods":["DELETE"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v2\/echo"}]}},"\/ldlms\/v2\/price-types":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v2\/price-types"}]}},"\/ldlms\/v2\/price-types\/(?P<slug>[\\w-]+)":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"An alphanumeric identifier for the price type.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed"],"default":"view","required":false}}}]},"\/ldlms\/v2\/question-types":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v2\/question-types"}]}},"\/ldlms\/v2\/question-types\/(?P<slug>[\\w-]+)":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"An alphanumeric identifier for the  type","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed"],"default":"view","required":false}}}]},"\/ldlms\/v2\/progress-status":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v2\/progress-status"}]}},"\/ldlms\/v2\/progress-status\/(?P<slug>[\\w-]+)":{"namespace":"ldlms\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"An alphanumeric identifier for the progress status.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed"],"default":"view","required":false}}}]},"\/ldlms\/v2\/exams":{"namespace":"ldlms\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/ldlms\/v2\/exams"}]}},"\/ldlms\/v2\/exams\/(?P<id>[\\d]+)":{"namespace":"ldlms\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"Sauter la poubelle et forcer la suppression.","required":false}}}]},"\/zipwp\/v1":{"namespace":"zipwp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"zipwp\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1"}]}},"\/zipwp\/v1\/get-credits":{"namespace":"zipwp\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/get-credits"}]}},"\/zipwp\/v1\/zip-plan":{"namespace":"zipwp\/v1","methods":["POST","POST"],"endpoints":[{"methods":["POST"],"args":[]},{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/zip-plan"}]}},"\/zipwp\/v1\/revoke-access":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/revoke-access"}]}},"\/hfe\/v1":{"namespace":"hfe\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"hfe\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/hfe\/v1"}]}},"\/hfe\/v1\/widgets":{"namespace":"hfe\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/hfe\/v1\/widgets"}]}},"\/hfe\/v1\/plugins":{"namespace":"hfe\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/hfe\/v1\/plugins"}]}},"\/hfe\/v1\/templates":{"namespace":"hfe\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/hfe\/v1\/templates"}]}},"\/hfe\/v1\/email-webhook":{"namespace":"hfe\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/hfe\/v1\/email-webhook"}]}},"\/hfe\/v1\/recommended-plugins":{"namespace":"hfe\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/hfe\/v1\/recommended-plugins"}]}},"\/yoast\/v1\/redirects":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"origin":{"type":"string","description":"The origin to redirect","required":true},"target":{"type":"string","description":"The redirect target","required":false},"type":{"type":"integer","description":"The redirect type","required":true},"ignore_warning":{"type":"boolean","description":"Whether to ignore warnings","default":false,"required":false},"format":{"description":"Le format de la redirection \u00e0 cr\u00e9er.","type":"string","enum":["plain","regex"],"default":"plain","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/redirects"}]}},"\/yoast\/v1\/redirects\/delete":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"origin":{"type":"string","description":"The origin to redirect","required":true},"target":{"type":"string","description":"The redirect target","required":false},"type":{"type":"string","description":"The redirect format","required":false},"ignore_warning":{"type":"boolean","description":"Whether to ignore warnings","default":false,"required":false},"format":{"description":"Le format de la redirection \u00e0 cr\u00e9er.","type":"string","enum":["plain","regex"],"default":"plain","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/redirects\/delete"}]}},"\/yoast\/v1\/redirects\/list":{"namespace":"yoast\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"format":{"description":"Le format des redirections \u00e0 r\u00e9cup\u00e9rer.","type":"string","enum":["plain","regex"],"default":"plain","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/redirects\/list"}]}},"\/yoast\/v1\/redirects\/update":{"namespace":"yoast\/v1","methods":["PUT"],"endpoints":[{"methods":["PUT"],"args":{"old_origin":{"type":"string","description":"The origin to redirect (old)","required":true},"old_target":{"type":"string","description":"The redirect target (old)","required":false},"old_type":{"type":"integer","description":"The redirect type (old)","required":true},"new_origin":{"type":"string","description":"The origin to redirect (new)","required":true},"new_target":{"type":"string","description":"The redirect target (new)","required":false},"new_type":{"type":"integer","description":"The redirect type (new)","required":true},"ignore_warning":{"type":"boolean","description":"Whether to ignore warnings","default":false,"required":false},"format":{"description":"Le format des redirections \u00e0 r\u00e9cup\u00e9rer.","type":"string","enum":["plain","regex"],"default":"plain","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/redirects\/update"}]}},"\/yoast\/v1\/redirects\/settings":{"namespace":"yoast\/v1","methods":["GET","PUT"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["PUT"],"args":{"disable_php_redirect":{"description":"Indiquez si les redirections bas\u00e9es sur PHP doivent \u00eatre d\u00e9sactiv\u00e9es et si .htaccess doit \u00eatre utilis\u00e9 \u00e0 la place.","type":"string","enum":["on","off"],"required":true},"separate_file":{"description":"Indiquer si les redirections doivent \u00eatre \u00e9crites dans un fichier s\u00e9par\u00e9 au lieu du .htaccess.","type":"string","enum":["on","off"],"required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/redirects\/settings"}]}},"\/yoast\/v1\/redirects\/undo-for-object":{"namespace":"yoast\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"obj_id":{"type":"int","description":"The id of the post or term","required":true},"obj_type":{"type":"string","description":"The object type: post or term","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/yoast\/v1\/redirects\/undo-for-object"}]}},"\/zipwp\/v1\/description":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_name":{"type":"string","required":true},"business_description":{"type":"string","required":false},"category":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/description"}]}},"\/zipwp\/v1\/images":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keywords":{"type":"string","required":true},"per_page":{"type":"string","required":false},"page":{"type":"string","required":false},"orientation":{"type":"string","required":false},"engine":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/images"}]}},"\/zipwp\/v1\/keywords":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_name":{"type":"string","required":true},"business_description":{"type":"string","required":false},"category":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/keywords"}]}},"\/zipwp\/v1\/template-keywords":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_name":{"type":"string","required":true},"business_description":{"type":"string","required":false},"business_category":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/template-keywords"}]}},"\/zipwp\/v1\/categories":{"namespace":"zipwp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/categories"}]}},"\/zipwp\/v1\/site-features":{"namespace":"zipwp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/site-features"}]}},"\/zipwp\/v1\/site-languages":{"namespace":"zipwp\/v1","methods":["GET","GET"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/site-languages"}]}},"\/zipwp\/v1\/import-status":{"namespace":"zipwp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/import-status"}]}},"\/zipwp\/v1\/migration-status":{"namespace":"zipwp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/migration-status"}]}},"\/zipwp\/v1\/templates":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_name":{"type":"string","required":false},"keyword":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/templates"}]}},"\/zipwp\/v1\/all-templates":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_name":{"type":"string","required":false},"per_page":{"type":"integer","required":false},"page":{"type":"integer","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/all-templates"}]}},"\/zipwp\/v1\/user-details":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_description":{"type":"string","required":true},"business_name":{"type":"string","required":true},"business_addeess":{"type":"string","required":false},"business_phone":{"type":"string","required":false},"business_email":{"type":"string","required":false},"social_profiles":{"type":"array","required":false},"business_category":{"type":"string","required":true},"site_language":{"type":"string","required":true},"keywords":{"type":"array","required":true},"images":{"type":"array","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/user-details"}]}},"\/zipwp\/v1\/site":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"template":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/site"}]}},"\/zipwp\/v1\/wxr":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"template":{"type":"string","required":true},"business_name":{"type":"string","required":false},"business_description":{"type":"string","required":false},"language":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/wxr"}]}},"\/zipwp\/v1\/ai-site":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"template":{"type":"string","required":true},"business_name":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/ai-site"}]}},"\/zipwp\/v1\/search-category":{"namespace":"zipwp\/v1","methods":["POST","POST"],"endpoints":[{"methods":["POST"],"args":{"keyword":{"type":"string","required":true}}},{"methods":["POST"],"args":{"keyword":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/search-category"}]}},"\/zipwp\/v1\/import-error-log":{"namespace":"zipwp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/import-error-log"}]}},"\/zipwp\/v1\/set-step-data":{"namespace":"zipwp\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_details":{"type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/set-step-data"}]}},"\/zipwp\/v1\/set-plan-promo-dismiss-time":{"namespace":"zipwp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/set-plan-promo-dismiss-time"}]}},"\/zipwp\/v1\/get-plan-promo-dismiss-time":{"namespace":"zipwp\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp\/v1\/get-plan-promo-dismiss-time"}]}},"\/astra\/v1":{"namespace":"astra\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"astra\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/astra\/v1"}]}},"\/astra\/v1\/admin\/settings":{"namespace":"astra\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/astra\/v1\/admin\/settings"}]}},"\/elementor\/v1":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"elementor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/elementor\/v1"}]}},"\/elementor\/v1\/globals":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/elementor\/v1\/globals"}]}},"\/elementor\/v1\/globals\/colors":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/elementor\/v1\/globals\/colors"}]}},"\/elementor\/v1\/globals\/colors\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/globals\/typography":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/elementor\/v1\/globals\/typography"}]}},"\/elementor\/v1\/globals\/typography\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["POST"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Unique identifier for the object.","type":"string","required":true}}}]},"\/elementor\/v1\/favorites":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/elementor\/v1\/favorites"}]}},"\/elementor\/v1\/favorites\/(?P<id>[\\w]+)":{"namespace":"elementor\/v1","methods":["POST","DELETE"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Type of favorites.","type":"string","required":true},"favorite":{"description":"The favorite slug to create.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Type of favorites.","type":"string","required":true},"favorite":{"description":"The favorite slug to delete.","type":"string","required":true}}}]},"\/elementor\/v1\/kit-elements-defaults":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/elementor\/v1\/kit-elements-defaults"}]}},"\/elementor\/v1\/kit-elements-defaults\/(?P<type>[\\w\\-\\_]+)":{"namespace":"elementor\/v1","methods":["POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["POST","PUT","PATCH"],"args":{"type":{"type":"string","description":"The type of the element.","required":true},"settings":{"description":"All the default values for the requested type","type":"object","required":true}}},{"methods":["DELETE"],"args":{"type":{"type":"string","description":"The type of the element.","required":true}}}]},"\/elementor\/v1\/site-navigation\/recent-posts":{"namespace":"elementor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"posts_per_page":{"description":"Number of posts to return","type":"integer","required":true},"post_type":{"description":"Post types to retrieve","type":"array","default":["page","post","elementor_library"],"required":false},"post__not_in":{"description":"Post id`s to exclude","type":"array","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/elementor\/v1\/site-navigation\/recent-posts"}]}},"\/elementor\/v1\/site-navigation\/add-new-post":{"namespace":"elementor\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"post_type":{"description":"Post type to create","type":"string","default":"post","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/elementor\/v1\/site-navigation\/add-new-post"}]}},"\/elementor\/v1\/template-library\/templates":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST"],"args":{"title":{"type":"string","description":"The title of the document","required":false},"type":{"description":"The document type.","type":"string","enum":["page","section","landing-page"],"required":true},"content":{"description":"Elementor data object","type":"object","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/elementor\/v1\/template-library\/templates"}]}},"\/zipwp-images\/v1":{"namespace":"zipwp-images\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"zipwp-images\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp-images\/v1"}]}},"\/zipwp-images\/v1\/images":{"namespace":"zipwp-images\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keywords":{"type":"string","required":true},"per_page":{"type":"string","required":false},"page":{"type":"string","required":false},"orientation":{"type":"string","required":false},"engine":{"type":"string","required":false},"filter":{"type":"string","required":false},"color":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/zipwp-images\/v1\/images"}]}},"\/nps-survey\/v1":{"namespace":"nps-survey\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"nps-survey\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/nps-survey\/v1"}]}},"\/nps-survey\/v1\/rating":{"namespace":"nps-survey\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/nps-survey\/v1\/rating"}]}},"\/nps-survey\/v1\/dismiss-nps-survey":{"namespace":"nps-survey\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/nps-survey\/v1\/dismiss-nps-survey"}]}},"\/gutenberg-templates\/v1":{"namespace":"gutenberg-templates\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"gutenberg-templates\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/gutenberg-templates\/v1"}]}},"\/gutenberg-templates\/v1\/categories":{"namespace":"gutenberg-templates\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/gutenberg-templates\/v1\/categories"}]}},"\/gutenberg-templates\/v1\/description":{"namespace":"gutenberg-templates\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_name":{"type":"string","required":true},"business_description":{"type":"string","required":false},"category":{"type":"string","required":false},"language_name":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/gutenberg-templates\/v1\/description"}]}},"\/gutenberg-templates\/v1\/page-description":{"namespace":"gutenberg-templates\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_name":{"type":"string","required":true},"business_description":{"type":"string","required":false},"page_name":{"type":"string","required":true},"page_description":{"type":"string","required":false},"category":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/gutenberg-templates\/v1\/page-description"}]}},"\/gutenberg-templates\/v1\/keywords":{"namespace":"gutenberg-templates\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"business_name":{"type":"string","required":true},"business_description":{"type":"string","required":false},"category":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/gutenberg-templates\/v1\/keywords"}]}},"\/gutenberg-templates\/v1\/images":{"namespace":"gutenberg-templates\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"keywords":{"type":"string","required":true},"per_page":{"type":"integer","required":false},"page":{"type":"integer","required":false},"orientation":{"type":"string","required":false},"engine":{"type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/gutenberg-templates\/v1\/images"}]}},"\/gutenberg-templates\/v1\/settings":{"namespace":"gutenberg-templates\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"key":{"type":"string","required":true},"value":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/gutenberg-templates\/v1\/settings"}]}},"\/gutenberg-templates\/v1\/favorite":{"namespace":"gutenberg-templates\/v1","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"type":{"type":"string","required":true},"block_id":{"type":"integer","required":true},"status":{"type":"boolean","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/gutenberg-templates\/v1\/favorite"}]}},"\/gutenberg-templates\/v1\/do-it-later":{"namespace":"gutenberg-templates\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/gutenberg-templates\/v1\/do-it-later"}]}},"\/gutenberg-templates\/v1\/pages-onboarding":{"namespace":"gutenberg-templates\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/gutenberg-templates\/v1\/pages-onboarding"}]}},"\/gutenberg-templates\/v1\/revoke-access":{"namespace":"gutenberg-templates\/v1","methods":["POST"],"endpoints":[{"methods":["POST"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/gutenberg-templates\/v1\/revoke-access"}]}},"\/gutenberg-templates\/v1\/blocks":{"namespace":"gutenberg-templates\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/gutenberg-templates\/v1\/blocks"}]}},"\/gutenberg-templates\/v1\/setup":{"namespace":"gutenberg-templates\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/gutenberg-templates\/v1\/setup"}]}},"\/gutenberg-templates\/v1\/sites":{"namespace":"gutenberg-templates\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/gutenberg-templates\/v1\/sites"}]}},"\/elementor\/v1\/send-event":{"namespace":"elementor\/v1","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false}}},{"methods":["POST"],"args":{"event_data":{"description":"All the recorded event data in JSON format","type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/elementor\/v1\/send-event"}]}},"\/wp\/v2\/posts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"categories":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"categories_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie categories.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"include_children":{"description":"Possibilit\u00e9 d\u2019inclure des termes enfants dans les termes limitant le champs de r\u00e9sultats.","type":"boolean","default":false}},"additionalProperties":false}],"required":false},"tags":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"tags_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie tags.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"sticky":{"description":"Limiter les r\u00e9sultats aux \u00e9l\u00e9ments qui sont \u00e9pingl\u00e9s.","type":"boolean","required":false},"ignore_sticky":{"description":"Ignorer les publications \u00e9pingl\u00e9es ou non.","type":"boolean","default":true,"required":false},"format":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments auxquels un ou plusieurs formats sont assign\u00e9s.","type":"array","uniqueItems":true,"items":{"enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Le format pour la publication.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"D\u00e9finit si la publication doit \u00eatre trait\u00e9e en tant que contenu \u00e9pingl\u00e9 ou non.","type":"boolean","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/posts"}]}},"\/wp\/v2\/posts\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Surcharger la longueur par d\u00e9faut de l\u2019extrait.","type":"integer","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Le format pour la publication.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"D\u00e9finit si la publication doit \u00eatre trait\u00e9e en tant que contenu \u00e9pingl\u00e9 ou non.","type":"boolean","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/posts\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"format":{"description":"Le format pour la publication.","type":"string","enum":["standard","aside","chat","gallery","link","image","quote","status","video","audio"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"sticky":{"description":"D\u00e9finit si la publication doit \u00eatre trait\u00e9e en tant que contenu \u00e9pingl\u00e9 ou non.","type":"boolean","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/posts\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/pages":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments ayant un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les r\u00e9sultats, except\u00e9s ceux dont le parent porte un ID sp\u00e9cifique.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la publication.","type":"integer","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/pages"}]}},"\/wp\/v2\/pages\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Surcharger la longueur par d\u00e9faut de l\u2019extrait.","type":"integer","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"parent":{"description":"L\u2019ID du parent de la publication.","type":"integer","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/pages\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}]},"\/wp\/v2\/pages\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/media":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"parent":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments ayant un ID parent particulier.","type":"array","items":{"type":"integer"},"default":[],"required":false},"parent_exclude":{"description":"Limiter le jeu de r\u00e9sultats \u00e0 tous les r\u00e9sultats, except\u00e9s ceux dont le parent porte un ID sp\u00e9cifique.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"inherit","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["inherit","private","trash"],"type":"string"},"required":false},"media_type":{"default":null,"description":"Limite le jeu de r\u00e9sultats aux fichiers joints d\u2019un ou plusieurs types de m\u00e9dias particuliers.","type":"array","items":{"type":"string","enum":["image","video","audio","application","text"]},"required":false},"mime_type":{"default":null,"description":"Limite le jeu de r\u00e9sultats aux fichiers joints d\u2019un ou plusieurs types MIME particuliers.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"alt_text":{"description":"Texte alternatif propos\u00e9 si le fichier ne peut pas \u00eatre affich\u00e9.","type":"string","required":false},"caption":{"description":"La l\u00e9gende du fichier joint.","type":"object","properties":{"raw":{"description":"L\u00e9gende pour le fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"L\u00e9gende HTML pour le fichier joint, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"La description du fichier joint.","type":"object","properties":{"raw":{"description":"Description du fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Description HTML de la pi\u00e8ce jointe, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"L\u2019ID pour la publication associ\u00e9e au fichier.","type":"integer","required":false},"generate_sub_sizes":{"type":"boolean","default":true,"description":"G\u00e9n\u00e9rer ou non des sous-tailles d\u2019images.","required":false},"convert_format":{"type":"boolean","default":true,"description":"Convertir ou non les formats d\u2019images.","required":false},"url":{"type":"string","format":"uri","description":"URL d\u2019une image externe \u00e0 charger dans la m\u00e9diath\u00e8que au lieu de t\u00e9l\u00e9verser un fichier.","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/media"}]}},"\/wp\/v2\/media\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"alt_text":{"description":"Texte alternatif propos\u00e9 si le fichier ne peut pas \u00eatre affich\u00e9.","type":"string","required":false},"caption":{"description":"La l\u00e9gende du fichier joint.","type":"object","properties":{"raw":{"description":"L\u00e9gende pour le fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"L\u00e9gende HTML pour le fichier joint, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"La description du fichier joint.","type":"object","properties":{"raw":{"description":"Description du fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Description HTML de la pi\u00e8ce jointe, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"post":{"description":"L\u2019ID pour la publication associ\u00e9e au fichier.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/post-process":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identifiant unique du fichier joint.","type":"integer","required":false},"action":{"type":"string","enum":["create-image-subsizes"],"required":true}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/edit":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"src":{"description":"URL vers le fichier image modifi\u00e9.","type":"string","format":"uri","required":true},"modifiers":{"description":"Tableau des modifications d\u2019images.","type":"array","minItems":1,"items":{"description":"Modification d\u2019image.","type":"object","required":["type","args"],"oneOf":[{"title":"Retourner","properties":{"type":{"description":"Type de retournement.","type":"string","enum":["flip"]},"args":{"description":"Inverser les arguments.","type":"object","required":["flip"],"properties":{"flip":{"description":"Sens de retournement.","type":"object","required":["horizontal","vertical"],"properties":{"horizontal":{"description":"D\u00e9termine s\u2019il faut retourner dans le sens horizontal.","type":"boolean"},"vertical":{"description":"D\u00e9termine s\u2019il faut retourner dans le sens vertical.","type":"boolean"}}}}}}},{"title":"Rotation","properties":{"type":{"description":"Type de rotation.","type":"string","enum":["rotate"]},"args":{"description":"Arguments de rotation.","type":"object","required":["angle"],"properties":{"angle":{"description":"Angle de rotation dans le sens horaire en degr\u00e9s.","type":"number"}}}}},{"title":"Recadrer","properties":{"type":{"description":"Type de recadrage.","type":"string","enum":["crop"]},"args":{"description":"Arguments de recadrage.","type":"object","required":["left","top","width","height"],"properties":{"left":{"description":"Position horizontale \u00e0 partir de la gauche pour commencer le recadrage en pourcentage de la largeur de l\u2019image.","type":"number"},"top":{"description":"En pourcentage de l\u2019image, la position verticale \u00e0 partir du haut \u00e0 laquelle commencer le recadrage de l\u2019image.","type":"number"},"width":{"description":"Largeur du recadrage en pourcentage de la largeur de l\u2019image.","type":"number"},"height":{"description":"Hauteur du recadrage en pourcentage de la hauteur de l\u2019image.","type":"number"}}}}}]},"required":false},"rotation":{"description":"La valeur en degr\u00e9s de la rotation de l\u2019image dans le sens des aiguilles d\u2019une montre. Obsol\u00e8te\u00a0: utilisez `modifiers` \u00e0 la place.","type":"integer","minimum":0,"exclusiveMinimum":true,"maximum":360,"exclusiveMaximum":true,"required":false},"x":{"description":"En pourcentage de l\u2019image, la position X \u00e0 laquelle commencer le recadrage de l\u2019image. Obsol\u00e8te\u00a0: utilisez `modifiers` \u00e0 la place.","type":"number","minimum":0,"maximum":100,"required":false},"y":{"description":"En pourcentage de l\u2019image, la position Y \u00e0 laquelle commencer le recadrage de l\u2019image. Obsol\u00e8te\u00a0: utilisez `modifiers` \u00e0 la place.","type":"number","minimum":0,"maximum":100,"required":false},"width":{"description":"En pourcentage de l\u2019image, la largeur \u00e0 laquelle il faut recadrer l\u2019image. Obsol\u00e8te\u00a0: Utilisez `modifiers` \u00e0 la place.","type":"number","minimum":0,"maximum":100,"required":false},"height":{"description":"En pourcentage de l\u2019image, la hauteur \u00e0 laquelle il faut recadrer l\u2019image. Obsol\u00e8te\u00a0: Utilisez `modifiers` \u00e0 la place.","type":"number","minimum":0,"maximum":100,"required":false},"caption":{"description":"La l\u00e9gende du fichier joint.","type":"object","properties":{"raw":{"description":"L\u00e9gende pour le fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"L\u00e9gende HTML pour le fichier joint, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"La description du fichier joint.","type":"object","properties":{"raw":{"description":"Description du fichier joint, telle qu\u2019elle existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Description HTML de la pi\u00e8ce jointe, transform\u00e9e pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"post":{"description":"L\u2019ID pour la publication associ\u00e9e au fichier.","type":"integer","required":false},"alt_text":{"description":"Texte alternatif propos\u00e9 si le fichier ne peut pas \u00eatre affich\u00e9.","type":"string","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/sideload":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identifiant unique du fichier joint.","type":"integer","required":false},"image_size":{"description":"Taille de l\u2019image. Peut \u00eatre un nom de taille unique ou un tableau de noms de taille pour enregistrer le m\u00eame fichier sous plusieurs tailles.","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"convert_format":{"type":"boolean","default":true,"description":"Convertir ou non les formats d\u2019images.","required":false}}}]},"\/wp\/v2\/media\/(?P<id>[\\d]+)\/finalize":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"Identifiant unique du fichier joint.","type":"integer","required":false},"sub_sizes":{"description":"Tableau de m\u00e9tadonn\u00e9es de sous-taille collect\u00e9es \u00e0 partir des r\u00e9ponses de chargement lat\u00e9ral.","type":"array","default":[],"maxItems":100,"items":{"type":"object","properties":{"image_size":{"description":"Un nom de taille ou un tableau de noms de taille lorsqu\u2019un seul fichier est enregistr\u00e9 sous plusieurs tailles avec des dimensions correspondantes.","type":["string","array"],"items":{"type":"string","minLength":1},"minItems":1,"minLength":1,"required":true},"width":{"type":"integer","minimum":1},"height":{"type":"integer","minimum":1},"file":{"type":"string","minLength":1},"mime_type":{"type":"string","pattern":"^image\/.*"},"filesize":{"type":"integer","minimum":1},"original_image":{"type":"string","minLength":1}}},"required":false}}}]},"\/wp\/v2\/menu-items":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"menu_order","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"menus":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie menus.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"menus_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie menus.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"title":{"description":"Le titre pour l\u2019objet.","type":["string","object"],"properties":{"raw":{"description":"Le titre pour l\u2019objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour l\u2019objet, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"default":"custom","description":"La famille d\u2019objets originellement repr\u00e9sent\u00e9e comme \u00ab\u00a0type de publication\u00a0\u00bb ou \u00ab\u00a0taxonomie\u00a0\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"default":"publish","description":"Un \u00e9tat nomm\u00e9 pour l\u2019objet.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"parent":{"default":0,"description":"L\u2019ID pour le parent de l\u2019objet.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texte de l\u2019attribut titre de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"classes":{"description":"Noms de classe de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La description de cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"menu_order":{"default":1,"description":"L\u2019ID en base de donn\u00e9es due nav_menu_item qui est le parent de l\u2019\u00e9l\u00e9ment de menu, sinon 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Le type d\u2019objet originellement repr\u00e9sent\u00e9 comme \u00ab\u00a0cat\u00e9gorie\u00a0\u00bb, \u00ab\u00a0publication\u00a0\u00bb ou \u00ab\u00a0fichier joint\u00a0\u00bb.","type":"string","required":false},"object_id":{"default":0,"description":"L\u2019ID en base de donn\u00e9es de l\u2019objet original que repr\u00e9sente l\u2019\u00e9l\u00e9ment de menu, comme par exemple l\u2019ID pour les publication et le term_id pour les cat\u00e9gories.","type":"integer","minimum":0,"required":false},"target":{"description":"L\u2019attribut cible de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"L\u2019URL vers laquelle l\u2019\u00e9l\u00e9ment de menu renvoie.","type":"string","format":"uri","required":false},"xfn":{"description":"La relation XFN exprim\u00e9e dans ce lien de l\u2019\u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Les termes assign\u00e9s \u00e0 l\u2019objet dans la taxonomie nav_menu.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/menu-items"}]}},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"title":{"description":"Le titre pour l\u2019objet.","type":["string","object"],"properties":{"raw":{"description":"Le titre pour l\u2019objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour l\u2019objet, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"La famille d\u2019objets originellement repr\u00e9sent\u00e9e comme \u00ab\u00a0type de publication\u00a0\u00bb ou \u00ab\u00a0taxonomie\u00a0\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour l\u2019objet.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"parent":{"description":"L\u2019ID pour le parent de l\u2019objet.","type":"integer","minimum":0,"required":false},"attr_title":{"description":"Texte de l\u2019attribut titre de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"classes":{"description":"Noms de classe de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La description de cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"menu_order":{"description":"L\u2019ID en base de donn\u00e9es due nav_menu_item qui est le parent de l\u2019\u00e9l\u00e9ment de menu, sinon 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Le type d\u2019objet originellement repr\u00e9sent\u00e9 comme \u00ab\u00a0cat\u00e9gorie\u00a0\u00bb, \u00ab\u00a0publication\u00a0\u00bb ou \u00ab\u00a0fichier joint\u00a0\u00bb.","type":"string","required":false},"object_id":{"description":"L\u2019ID en base de donn\u00e9es de l\u2019objet original que repr\u00e9sente l\u2019\u00e9l\u00e9ment de menu, comme par exemple l\u2019ID pour les publication et le term_id pour les cat\u00e9gories.","type":"integer","minimum":0,"required":false},"target":{"description":"L\u2019attribut cible de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"L\u2019URL vers laquelle l\u2019\u00e9l\u00e9ment de menu renvoie.","type":"string","format":"uri","required":false},"xfn":{"description":"La relation XFN exprim\u00e9e dans ce lien de l\u2019\u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Les termes assign\u00e9s \u00e0 l\u2019objet dans la taxonomie nav_menu.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/menu-items\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID pour le parent de l\u2019objet.","type":"integer","minimum":0,"required":false},"title":{"description":"Le titre pour l\u2019objet.","type":["string","object"],"properties":{"raw":{"description":"Le titre pour l\u2019objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour l\u2019objet, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"type":{"description":"La famille d\u2019objets originellement repr\u00e9sent\u00e9e comme \u00ab\u00a0type de publication\u00a0\u00bb ou \u00ab\u00a0taxonomie\u00a0\u00bb.","type":"string","enum":["taxonomy","post_type","post_type_archive","custom"],"required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour l\u2019objet.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"attr_title":{"description":"Texte de l\u2019attribut titre de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"classes":{"description":"Noms de classe de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"description":{"description":"La description de cet \u00e9l\u00e9ment de menu.","type":"string","required":false},"menu_order":{"description":"L\u2019ID en base de donn\u00e9es due nav_menu_item qui est le parent de l\u2019\u00e9l\u00e9ment de menu, sinon 0.","type":"integer","minimum":1,"required":false},"object":{"description":"Le type d\u2019objet originellement repr\u00e9sent\u00e9 comme \u00ab\u00a0cat\u00e9gorie\u00a0\u00bb, \u00ab\u00a0publication\u00a0\u00bb ou \u00ab\u00a0fichier joint\u00a0\u00bb.","type":"string","required":false},"object_id":{"description":"L\u2019ID en base de donn\u00e9es de l\u2019objet original que repr\u00e9sente l\u2019\u00e9l\u00e9ment de menu, comme par exemple l\u2019ID pour les publication et le term_id pour les cat\u00e9gories.","type":"integer","minimum":0,"required":false},"target":{"description":"L\u2019attribut cible de l\u2019\u00e9l\u00e9ment lien pour cet \u00e9l\u00e9ment de menu.","type":"string","enum":["_blank",""],"required":false},"url":{"description":"L\u2019URL vers laquelle l\u2019\u00e9l\u00e9ment de menu renvoie.","type":"string","format":"uri","required":false},"xfn":{"description":"La relation XFN exprim\u00e9e dans ce lien de l\u2019\u00e9l\u00e9ment de menu.","type":"array","items":{"type":"string"},"required":false},"menus":{"description":"Les termes assign\u00e9s \u00e0 l\u2019objet dans la taxonomie nav_menu.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""}},"required":false}}}]},"\/wp\/v2\/menu-items\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/blocks":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false},"tax_relation":{"description":"Limiter le jeu de r\u00e9sultats en se basant sur les correspondances entre plusieurs taxonomies.","type":"string","enum":["AND","OR"],"required":false},"wp_pattern_category":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont des termes sp\u00e9cifiquement assign\u00e9s dans la taxonomie wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]},"operator":{"description":"Si les \u00e9l\u00e9ments doivent \u00eatre assign\u00e9s \u00e0 tous ou \u00e0 certains des termes sp\u00e9cifi\u00e9s.","type":"string","enum":["AND","OR"],"default":"OR"}},"additionalProperties":false}],"required":false},"wp_pattern_category_exclude":{"description":"Limiter le jeu de r\u00e9sultats aux \u00e9l\u00e9ments qui ont le terme sp\u00e9cifi\u00e9 assign\u00e9 dans la taxonomie wp_pattern_category.","type":["object","array"],"oneOf":[{"title":"Listes des ID de termes","description":"Faire correspondre les termes avec les ID list\u00e9s.","type":"array","items":{"type":"integer"}},{"title":"Requ\u00eate sur un ID de terme de taxonomie","description":"Effectuer une recherche de terme avanc\u00e9e.","type":"object","properties":{"terms":{"description":"ID de termes.","type":"array","items":{"type":"integer"},"default":[]}},"additionalProperties":false}],"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"wp_pattern_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/blocks"}]}},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"excerpt_length":{"description":"Surcharger la longueur par d\u00e9faut de l\u2019extrait.","type":"integer","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"wp_pattern_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/blocks\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"excerpt":{"description":"L\u2019extrait pour la publication.","type":"object","properties":{"raw":{"description":"L\u2019extrait pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Extrait HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si l\u2019extrait est prot\u00e9g\u00e9 par un mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"wp_pattern_sync_status":{"type":"string","title":"","description":"","default":"","enum":["partial","unsynced"]},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"wp_pattern_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie wp_pattern_category.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/blocks\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false}}}]},"\/wp\/v2\/templates\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/templates":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limiter \u00e0 l\u2019ID de publication sp\u00e9cifi\u00e9.","type":"integer","required":false},"area":{"description":"Limite \u00e0 la zone de l\u2019\u00e9l\u00e9ment de mod\u00e8le sp\u00e9cifi\u00e9.","type":"string","required":false},"post_type":{"description":"Type de publication pour lequel obtenir les mod\u00e8les.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"default":"","description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"default":"publish","description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/templates"}]}},"\/wp\/v2\/templates\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Le slug du mod\u00e8le doit r\u00e9cup\u00e9rer l\u2019alternative pour","type":"string","required":true},"is_custom":{"description":"Indique si un mod\u00e8le est personnalis\u00e9 ou fait partie de la hi\u00e9rarchie des mod\u00e8les.","type":"boolean","required":false},"template_prefix":{"description":"Le pr\u00e9fixe de mod\u00e8le pour le mod\u00e8le cr\u00e9\u00e9. Ceci est utilis\u00e9 pour extraire le type de mod\u00e8le principal, p.\u00a0ex.\u00a0dans \u00ab\u00a0taxonomy-books\u00a0\u00bb, cela extrait \u00ab\u00a0taxonomy\u00a0\u00bb","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/templates\/lookup"}]}},"\/wp\/v2\/templates\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false},"area":{"description":"L\u2019emplacement o\u00f9 l\u2019\u00e9l\u00e9ment de mod\u00e8le devrait \u00eatre utilis\u00e9 (ent\u00eate, pied de page, etc.)","type":"string","required":false}}}]},"\/wp\/v2\/template-parts\/(?P<parent>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/template-parts":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"wp_id":{"description":"Limiter \u00e0 l\u2019ID de publication sp\u00e9cifi\u00e9.","type":"integer","required":false},"area":{"description":"Limite \u00e0 la zone de l\u2019\u00e9l\u00e9ment de mod\u00e8le sp\u00e9cifi\u00e9.","type":"string","required":false},"post_type":{"description":"Type de publication pour lequel obtenir les mod\u00e8les.","type":"string","required":false}}},{"methods":["POST"],"args":{"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":true},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"default":"","description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"default":"","description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"default":"","description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"default":"publish","description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false},"area":{"description":"L\u2019emplacement o\u00f9 l\u2019\u00e9l\u00e9ment de mod\u00e8le devrait \u00eatre utilis\u00e9 (ent\u00eate, pied de page, etc.)","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/template-parts"}]}},"\/wp\/v2\/template-parts\/lookup":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Le slug du mod\u00e8le doit r\u00e9cup\u00e9rer l\u2019alternative pour","type":"string","required":true},"is_custom":{"description":"Indique si un mod\u00e8le est personnalis\u00e9 ou fait partie de la hi\u00e9rarchie des mod\u00e8les.","type":"boolean","required":false},"template_prefix":{"description":"Le pr\u00e9fixe de mod\u00e8le pour le mod\u00e8le cr\u00e9\u00e9. Ceci est utilis\u00e9 pour extraire le type de mod\u00e8le principal, p.\u00a0ex.\u00a0dans \u00ab\u00a0taxonomy-books\u00a0\u00bb, cela extrait \u00ab\u00a0taxonomy\u00a0\u00bb","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/template-parts\/lookup"}]}},"\/wp\/v2\/template-parts\/(?P<id>([^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)[\\\/\\w%-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"slug":{"description":"Slug unique identifiant le mod\u00e8le.","type":"string","minLength":1,"pattern":"[a-zA-Z0-9_\\%-]+","required":false},"theme":{"description":"Identifiant de th\u00e8me pour le mod\u00e8le.","type":"string","required":false},"type":{"description":"Type de mod\u00e8le.","type":"string","required":false},"content":{"description":"Contenu du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Contenu pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit"]},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par le mod\u00e8le.","type":"integer","context":["edit"],"readonly":true}},"required":false},"title":{"description":"Titre du mod\u00e8le.","type":["object","string"],"properties":{"raw":{"description":"Titre pour le mod\u00e8le, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Titre HTML du mod\u00e8le, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"description":{"description":"Description du mod\u00e8le.","type":"string","required":false},"status":{"description":"\u00c9tat du mod\u00e8le.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"author":{"description":"L\u2019ID de l\u2019auteur\/autrice du mod\u00e8le.","type":"integer","required":false},"area":{"description":"L\u2019emplacement o\u00f9 l\u2019\u00e9l\u00e9ment de mod\u00e8le devrait \u00eatre utilis\u00e9 (ent\u00eate, pied de page, etc.)","type":"string","required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"L\u2019ID du mod\u00e8le.","type":"string","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la r\u00e9vision des styles globaux.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision de styles globaux.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[\\\/\\s%\\w\\.\\(\\)\\[\\]\\@_\\-]+)\/variations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"L\u2019identifiant du th\u00e8me","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"stylesheet":{"description":"L\u2019identifiant du th\u00e8me","type":"string","required":false}}}]},"\/wp\/v2\/global-styles\/(?P<id>[\\\/\\d+]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":false},"args":{"id":{"description":"ID de la configuration de styles globaux.","type":"integer","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":false},"args":{"styles":{"description":"Styles globaux.","type":["object"],"required":false},"settings":{"description":"R\u00e9glages globaux.","type":["object"],"required":false},"title":{"description":"Titre de la variation de styles globaux.","type":["object","string"],"properties":{"raw":{"description":"Titre de la variation de styles globaux, tel qu\u2019il existe en base de donn\u00e9es.","type":"string","context":["view","edit","embed"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false}}}]},"\/wp\/v2\/navigation":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/navigation"}]}},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/navigation\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit","embed"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit","embed"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}]},"\/wp\/v2\/navigation\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/font-families":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"id","enum":["id","include"],"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"args":{"theme_json_version":{"description":"Version du sch\u00e9ma theme.json utilis\u00e9 pour les r\u00e9glages de typographie.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"d\u00e9claration font-family dans le format theme.json, encod\u00e9e comme une cha\u00eene.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/font-families"}]}},"\/wp\/v2\/font-families\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"theme_json_version":{"description":"Version du sch\u00e9ma theme.json utilis\u00e9 pour les r\u00e9glages de typographie.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_family_settings":{"description":"d\u00e9claration font-family dans le format theme.json, encod\u00e9e comme une cha\u00eene.","type":"string","required":true}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"L\u2019ID de la famille de polices parente de la police de caract\u00e8res.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"id","enum":["id","include"],"required":false}}},{"methods":["POST"],"args":{"font_family_id":{"description":"L\u2019ID de la famille de polices parente de la police de caract\u00e8res.","type":"integer","required":true},"theme_json_version":{"description":"Version du sch\u00e9ma theme.json utilis\u00e9 pour les r\u00e9glages de typographie.","type":"integer","default":3,"minimum":2,"maximum":3,"required":false},"font_face_settings":{"description":"D\u00e9claration font-face dans le format theme.json, encod\u00e9e comme une cha\u00eene.","type":"string","required":true}}}]},"\/wp\/v2\/font-families\/(?P<font_family_id>[\\d]+)\/font-faces\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"font_family_id":{"description":"L\u2019ID de la famille de polices parente de la police de caract\u00e8res.","type":"integer","required":true},"id":{"description":"Identifiant unique de la police de caract\u00e8res.","type":"integer","required":true},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"font_family_id":{"description":"L\u2019ID de la famille de polices parente de la police de caract\u00e8res.","type":"integer","required":true},"id":{"description":"Identifiant unique de la police de caract\u00e8res.","type":"integer","required":true},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/sfwd-courses\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/sfwd-courses\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/sfwd-courses\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"course_materials":{"description":"Cours Materials","type":"html","required":false},"course_price_type":{"description":"Cours Price Type","type":"string","enum":["open","closed","free","buynow","subscribe"],"required":false},"custom_button_label":{"description":"Custom Button Label","type":"text","required":false},"custom_button_url":{"description":"URL de bouton personnalis\u00e9","type":"text","required":false},"course_price":{"description":"Cours Prix","type":"text","required":false},"course_prerequisite_enabled":{"description":"Activer les pr\u00e9-requis du Cours","type":"boolean","required":false},"course_prerequisite":{"description":"Cours Prerequisites","type":"array","required":false},"course_prerequisite_compare":{"description":"Cours Prerequisites Compare","type":"string","enum":["ANY","ALL"],"required":false},"course_points_enabled":{"description":"Activer Cours les Points","type":"boolean","required":false},"course_points":{"description":"Cours Points","type":"number","required":false},"course_points_access":{"description":"Cours Points Access","type":"number","required":false},"course_disable_lesson_progression":{"description":"Disable Le\u00e7on Progression","type":"boolean","required":false},"expire_access":{"description":"Dur\u00e9e d\u00e9finie","type":"boolean","required":false},"expire_access_days":{"description":"Acc\u00e8s ferm\u00e9 apr\u00e8s X jours","type":"number","required":false},"expire_access_delete_progress":{"description":"Delete Cours and Quiz Data After Expiration","type":"boolean","required":false}}}]},"\/wp\/v2\/sfwd-courses\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/sfwd-lessons\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/sfwd-lessons\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/sfwd-lessons\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"lesson_materials":{"description":"Le\u00e7on Documents","type":"html","required":false},"forced_lesson_time":{"description":"Forced Le\u00e7on Timer","type":"text","required":false},"lesson_assignment_upload":{"description":"Devoirs \u00e0 t\u00e9l\u00e9charger","type":"boolean","required":false},"auto_approve_assignment":{"description":"Approuver Automatiquement les Devoirs","type":"boolean","required":false},"assignment_upload_limit_count":{"description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_deletion_enabled":{"description":"Allow Student to Delete own Assignment(s)","type":"boolean","required":false},"lesson_assignment_points_enabled":{"description":"Donner des points pour le Devoir","type":"boolean","required":false},"lesson_assignment_points_amount":{"description":"Donner les Nombre de Points pour le Devoir","type":"number","required":false},"assignment_upload_limit_extensions":{"description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"description":"Allowed File Size","type":"text","required":false},"visible_after":{"description":"Rendre cette Le\u00e7on visible X jours apr\u00e8s l&#039;inscription.","type":"number","required":false},"visible_after_specific_date":{"description":"Make Le\u00e7on Visible on Specific Date","type":"wp_date_selector","required":false}}}]},"\/wp\/v2\/sfwd-lessons\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/sfwd-topic\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/sfwd-topic\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/sfwd-topic\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"ld_topic_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_topic_category.","type":"array","items":{"type":"integer"},"required":false},"ld_topic_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_topic_tag.","type":"array","items":{"type":"integer"},"required":false},"topic_materials":{"description":"Chapitre Documents","type":"html","required":false},"forced_lesson_time":{"description":"Forced Chapitre Timer","type":"text","required":false},"lesson_assignment_upload":{"description":"Devoirs \u00e0 t\u00e9l\u00e9charger","type":"boolean","required":false},"auto_approve_assignment":{"description":"Approuver Automatiquement les Devoirs","type":"boolean","required":false},"assignment_upload_limit_count":{"description":"Limit number of uploaded files","type":"number","required":false},"lesson_assignment_points_enabled":{"description":"Donner des points pour le Devoir","type":"boolean","required":false},"lesson_assignment_points_amount":{"description":"Donner les Nombre de Points pour le Devoir","type":"number","required":false},"assignment_upload_limit_extensions":{"description":"Allowed File Extensions","type":"text","required":false},"assignment_upload_limit_size":{"description":"Allowed File Size","type":"text","required":false}}}]},"\/wp\/v2\/sfwd-topic\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/sfwd-quiz\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/sfwd-quiz\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/sfwd-quiz\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"quiz_materials":{"description":"Quiz Documents","type":"html","required":false},"threshold":{"description":"Seuil de certificat","type":"text","required":false},"passingpercentage":{"description":"Pourcentage de passage","type":"text","required":false},"certificate":{"description":"Certificat associ\u00e9","type":"string","required":false}}}]},"\/wp\/v2\/sfwd-quiz\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/sfwd-question":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"menu_order":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant une valeur menu_order sp\u00e9cifique.","type":"integer","required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","menu_order"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"quiz":{"default":"","description":"Quiz ID.","type":"integer","required":false},"question_type":{"default":"single","description":"Question type.","type":"enum","enum":["single","multiple","free_answer","sort_answer","matrix_sort_answer","cloze_answer","assessment_answer","essay"],"required":false},"points_total":{"default":"","description":"Total Points amount","type":"integer","required":false},"points_per_answer":{"default":"","description":"Diff\u00e9rents points pour chaque r\u00e9ponse","type":"boolean","required":false},"points_show_in_message":{"default":"","description":"Show reached points in the correct\/incorrect message?","type":"boolean","required":false},"points_diff_modus":{"default":"","description":"Points diff\u00e9rents - mode 2 activ\u00e9","type":"boolean","required":false},"disable_correct":{"default":"","description":"Disable answer correct setting.","type":"boolean","required":false},"correct_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"incorrect_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"correct_same":{"default":"","description":"Activate hint for this Question.","type":"boolean","required":false},"hints_enabled":{"default":"","description":"Activate hint for this Question.","type":"boolean","required":false},"hints_message":{"description":"Hint message.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"answers":{"description":"Question answer sets.","type":"object","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/sfwd-question"}]}},"\/wp\/v2\/sfwd-question\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"quiz":{"description":"Quiz ID.","type":"integer","required":false},"question_type":{"description":"Question type.","type":"enum","enum":["single","multiple","free_answer","sort_answer","matrix_sort_answer","cloze_answer","assessment_answer","essay"],"required":false},"points_total":{"description":"Total Points amount","type":"integer","required":false},"points_per_answer":{"description":"Diff\u00e9rents points pour chaque r\u00e9ponse","type":"boolean","required":false},"points_show_in_message":{"description":"Show reached points in the correct\/incorrect message?","type":"boolean","required":false},"points_diff_modus":{"description":"Points diff\u00e9rents - mode 2 activ\u00e9","type":"boolean","required":false},"disable_correct":{"description":"Disable answer correct setting.","type":"boolean","required":false},"correct_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"incorrect_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"correct_same":{"description":"Activate hint for this Question.","type":"boolean","required":false},"hints_enabled":{"description":"Activate hint for this Question.","type":"boolean","required":false},"hints_message":{"description":"Hint message.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"answers":{"description":"Question answer sets.","type":"object","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/sfwd-question\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/sfwd-question\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/sfwd-question\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"menu_order":{"description":"L\u2019ordre de la publication en fonction des autres publications.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"quiz":{"description":"Quiz ID.","type":"integer","required":false},"question_type":{"description":"Question type.","type":"enum","enum":["single","multiple","free_answer","sort_answer","matrix_sort_answer","cloze_answer","assessment_answer","essay"],"required":false},"points_total":{"description":"Total Points amount","type":"integer","required":false},"points_per_answer":{"description":"Diff\u00e9rents points pour chaque r\u00e9ponse","type":"boolean","required":false},"points_show_in_message":{"description":"Show reached points in the correct\/incorrect message?","type":"boolean","required":false},"points_diff_modus":{"description":"Points diff\u00e9rents - mode 2 activ\u00e9","type":"boolean","required":false},"disable_correct":{"description":"Disable answer correct setting.","type":"boolean","required":false},"correct_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"incorrect_message":{"description":"Message shown when Question is correct.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"correct_same":{"description":"Activate hint for this Question.","type":"boolean","required":false},"hints_enabled":{"description":"Activate hint for this Question.","type":"boolean","required":false},"hints_message":{"description":"Hint message.","type":"object","properties":{"raw":{"description":"Content for the object, as it exists in the database.","type":"string","context":["edit"]},"rendered":{"description":"HTML content for the object, transformed for display.","type":"string","context":["view","edit"],"readonly":true}},"required":false},"answers":{"description":"Question answer sets.","type":"object","required":false}}}]},"\/wp\/v2\/sfwd-question\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/ld-exam":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"publish","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["publish","future","draft","pending","private","trash","auto-draft","inherit","request-pending","request-confirmed","request-failed","request-completed","flamingo-spam","graded","not_graded","rejected","any"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/ld-exam"}]}},"\/wp\/v2\/ld-exam\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/ld-exam\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/ld-exam\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/ld-exam\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""},"footnotes":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false}}}]},"\/wp\/v2\/ld-exam\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/groups\/(?P<parent>[\\d]+)\/revisions":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut d\u2019objet.","type":"string","default":"date","enum":["date","id","include","relevance","slug","include_slugs","title"],"required":false}}}]},"\/wp\/v2\/groups\/(?P<parent>[\\d]+)\/revisions\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","DELETE"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["DELETE"],"args":{"parent":{"description":"L\u2019ID pour le parent de la r\u00e9vision.","type":"integer","required":false},"id":{"description":"Identifiant unique pour la r\u00e9vision.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les r\u00e9visions ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/groups\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"featured_media":{"description":"L\u2019ID du m\u00e9dia mis en avant pour la publication.","type":"integer","required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"categories":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie category.","type":"array","items":{"type":"integer"},"required":false},"tags":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie post_tag.","type":"array","items":{"type":"integer"},"required":false},"ld_group_category":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_category.","type":"array","items":{"type":"integer"},"required":false},"ld_group_tag":{"description":"Les termes assign\u00e9s \u00e0 la publication dans la taxonomie ld_group_tag.","type":"array","items":{"type":"integer"},"required":false}}}]},"\/wp\/v2\/groups\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/sfwd-essays":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["graded","not_graded"],"type":"string"},"required":false},"course":{"description":"Filter by Cours ID","type":"integer","required":false},"lesson":{"description":"Filter by Le\u00e7on ID","type":"integer","default":0,"required":false},"topic":{"description":"Filter by Chapitre ID","type":"integer","default":0,"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"course":{"default":0,"description":"Cours ID","type":"integer","required":false},"lesson":{"default":0,"description":"Le\u00e7on ID","type":"integer","required":false},"topic":{"default":0,"description":"Chapitre ID","type":"integer","required":false},"points_max":{"default":0,"description":"Essay Points Maximum","type":"integer","required":false},"points_awarded":{"default":0,"description":"Essay Points Awarded","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/sfwd-essays"}]}},"\/wp\/v2\/sfwd-essays\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"course":{"description":"Cours ID","type":"integer","required":false},"lesson":{"description":"Le\u00e7on ID","type":"integer","required":false},"topic":{"description":"Chapitre ID","type":"integer","required":false},"points_max":{"description":"Essay Points Maximum","type":"integer","required":false},"points_awarded":{"description":"Essay Points Awarded","type":"integer","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/sfwd-essays\/(?P<id>[\\d]+)\/autosaves":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"content":{"description":"Le contenu pour cette publication.","type":"object","properties":{"raw":{"description":"Contenu pour cet objet, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour la publication, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit"],"readonly":true},"block_version":{"description":"Version du format de bloc de contenu utilis\u00e9 par l\u2019objet.","type":"integer","context":["edit"],"readonly":true},"protected":{"description":"D\u00e9finit si le contenu est prot\u00e9g\u00e9 par mot de passe ou non.","type":"boolean","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"course":{"description":"Cours ID","type":"integer","required":false},"lesson":{"description":"Le\u00e7on ID","type":"integer","required":false},"topic":{"description":"Chapitre ID","type":"integer","required":false},"points_max":{"description":"Essay Points Maximum","type":"integer","required":false},"points_awarded":{"description":"Essay Points Awarded","type":"integer","required":false}}}]},"\/wp\/v2\/sfwd-essays\/(?P<parent>[\\d]+)\/autosaves\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"parent":{"description":"L\u2019ID du parent de la sauvegarde automatique.","type":"integer","required":false},"id":{"description":"L\u2019identifiant de la sauvegarde automatique.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/sfwd-assignment":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_after":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es apr\u00e8s une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter les r\u00e9sultats aux publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les publications assign\u00e9es \u00e0 des auteurs ou autrices sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"before":{"description":"Limiter la r\u00e9ponse aux publications mises en ligne avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"modified_before":{"description":"Limiter la r\u00e9ponse aux publications modifi\u00e9es avant une date d\u00e9finie et conforme \u00e0 la norme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"search_semantics":{"description":"Comment interpr\u00e9ter le terme recherch\u00e9.","type":"string","enum":["exact"],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title"],"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["post_title","post_content","post_excerpt"],"type":"string"},"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux publications ayant au moins un slug particulier.","type":"array","items":{"type":"string"},"required":false},"status":{"default":"any","description":"Limiter le jeu de r\u00e9sultats aux publications associ\u00e9es \u00e0 un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["graded","not_graded"],"type":"string"},"required":false},"course":{"description":"Filter by Cours ID","type":"integer","required":false},"lesson":{"description":"Filter by Le\u00e7on ID","type":"integer","default":0,"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"course":{"default":0,"description":"Cours ID","type":"integer","required":false},"lesson":{"default":0,"description":"Le\u00e7on ID","type":"integer","required":false},"topic":{"default":0,"description":"Chapitre ID","type":"integer","required":false},"approved_status":{"default":"","description":"Assignment Approved Status","type":"string","enum":["","approved","not_approved"],"required":false},"points_enabled":{"default":0,"description":"Assignment Points Enabled","type":"boolean","required":false},"points_max":{"default":0,"description":"Assignment Points Maximum","type":"integer","required":false},"points_awarded":{"default":0,"description":"Assignment Points Awarded","type":"integer","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/sfwd-assignment"}]}},"\/wp\/v2\/sfwd-assignment\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"date":{"description":"La date de publication de l\u2019article, dans le fuseau horaire du site.","type":["string","null"],"format":"date-time","required":false},"date_gmt":{"description":"La date de mise en ligne de la publication, au format GMT.","type":["string","null"],"format":"date-time","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour la publication, propre au type de la ressource.","type":"string","required":false},"status":{"description":"Un \u00e9tat nomm\u00e9 pour la publication.","type":"string","enum":["publish","future","draft","pending","private","flamingo-spam","graded","not_graded","rejected"],"required":false},"password":{"description":"Un mot de passe pour prot\u00e9ger l\u2019acc\u00e8s au contenu et \u00e0 l\u2019extrait.","type":"string","required":false},"title":{"description":"Le titre de la publication.","type":"object","properties":{"raw":{"description":"Le titre pour la publication, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Le titre HTML pour la publication, mis en forme pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"author":{"description":"L\u2019ID pour l\u2019auteur ou l\u2019autrice de la publication.","type":"integer","required":false},"comment_status":{"description":"D\u00e9finit si les commentaires sont ouverts ou non pour cette publication.","type":"string","enum":["open","closed"],"required":false},"ping_status":{"description":"D\u00e9finit si l\u2019objet peut recevoir un ping ou non.","type":"string","enum":["open","closed"],"required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"site-sidebar-layout":{"type":"string","title":"","description":"","default":"default"},"site-content-layout":{"type":"string","title":"","description":"","default":"default"},"ast-global-header-display":{"type":"string","title":"","description":"","default":""},"ast-main-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-above-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-below-header-display":{"type":"string","title":"","description":"","default":""},"ast-hfb-mobile-header-display":{"type":"string","title":"","description":"","default":""},"site-post-title":{"type":"string","title":"","description":"","default":""},"ast-breadcrumbs-content":{"type":"string","title":"","description":"","default":""},"ast-featured-img":{"type":"string","title":"","description":"","default":""},"footer-sml-layout":{"type":"string","title":"","description":"","default":""},"theme-transparent-header-meta":{"type":"string","title":"","description":"","default":""},"adv-header-id-meta":{"type":"string","title":"","description":"","default":""},"stick-header-meta":{"type":"string","title":"","description":"","default":""},"header-above-stick-meta":{"type":"string","title":"","description":"","default":""},"header-main-stick-meta":{"type":"string","title":"","description":"","default":""},"header-below-stick-meta":{"type":"string","title":"","description":"","default":""}},"required":false},"template":{"description":"Le fichier de th\u00e8me \u00e0 utiliser pour afficher la publication.","type":"string","required":false},"course":{"description":"Cours ID","type":"integer","required":false},"lesson":{"description":"Le\u00e7on ID","type":"integer","required":false},"topic":{"description":"Chapitre ID","type":"integer","required":false},"approved_status":{"description":"Assignment Approved Status","type":"string","enum":["","approved","not_approved"],"required":false},"points_enabled":{"description":"Assignment Points Enabled","type":"boolean","required":false},"points_max":{"description":"Assignment Points Maximum","type":"integer","required":false},"points_awarded":{"description":"Assignment Points Awarded","type":"integer","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identifiant unique pour la publication.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false}}}]},"\/wp\/v2\/types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/types"}]}},"\/wp\/v2\/types\/(?P<type>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"type":{"description":"Un identificateur alphanum\u00e9rique pour le type de publication.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/statuses":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/statuses"}]}},"\/wp\/v2\/statuses\/(?P<status>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Un identificateur alphanum\u00e9rique pour l\u2019\u00e9tat.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/taxonomies":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"type":{"description":"Limiter les r\u00e9sultats aux taxonomies associ\u00e9es un type de publication sp\u00e9cifique.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/taxonomies"}]}},"\/wp\/v2\/taxonomies\/(?P<taxonomy>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"taxonomy":{"description":"Un identificateur alphanum\u00e9rique pour la taxonomie.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/categories":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"parent":{"description":"R\u00e9sultats limit\u00e9s aux termes ayant un parent sp\u00e9cifique.","type":"integer","required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/categories"}]}},"\/wp\/v2\/categories\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/tags":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/tags"}]}},"\/wp\/v2\/tags\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/menus":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false},"locations":{"description":"Les emplacements assign\u00e9s au menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ajouter automatiquement les pages de premier niveau \u00e0 ce menu.","type":"boolean","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/menus"}]}},"\/wp\/v2\/menus\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false},"locations":{"description":"Les emplacements assign\u00e9s au menu.","type":"array","items":{"type":"string"},"required":false},"auto_add":{"description":"Ajouter automatiquement les pages de premier niveau \u00e0 ce menu.","type":"boolean","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/wp_pattern_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/wp_pattern_category"}]}},"\/wp\/v2\/wp_pattern_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/ld_topic_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"parent":{"description":"R\u00e9sultats limit\u00e9s aux termes ayant un parent sp\u00e9cifique.","type":"integer","required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/ld_topic_category"}]}},"\/wp\/v2\/ld_topic_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/ld_topic_tag":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/ld_topic_tag"}]}},"\/wp\/v2\/ld_topic_tag\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/ld_group_category":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"parent":{"description":"R\u00e9sultats limit\u00e9s aux termes ayant un parent sp\u00e9cifique.","type":"integer","required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/ld_group_category"}]}},"\/wp\/v2\/ld_group_category\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"parent":{"description":"L\u2019ID du terme parent.","type":"integer","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/ld_group_tag":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"asc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de terme.","type":"string","default":"name","enum":["id","include","name","slug","include_slugs","term_group","description","count"],"required":false},"hide_empty":{"description":"D\u00e9termine s\u2019il faut masquer ou non des termes non affect\u00e9s \u00e0 des publications.","type":"boolean","default":false,"required":false},"post":{"description":"Limiter le r\u00e9sultat aux termes assign\u00e9s \u00e0 une publication sp\u00e9cifique.","type":"integer","default":null,"required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux termes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":true},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/ld_group_tag"}]}},"\/wp\/v2\/ld_group_tag\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"description":{"description":"Description HTML du terme.","type":"string","required":false},"name":{"description":"Titre HTML pour le terme.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le terme, propre au type de la ressource.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":[],"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le terme.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les termes ne prennent pas en charge la suppression forc\u00e9e.","required":false}}}]},"\/wp\/v2\/users":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"default":"asc","description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","enum":["asc","desc"],"type":"string","required":false},"orderby":{"default":"name","description":"Trier la collection par attributs de compte.","enum":["id","include","name","registered_date","slug","include_slugs","email","url"],"type":"string","required":false},"slug":{"description":"Limiter le jeu de r\u00e9sultats aux comptes ayant un ou plusieurs identifiants sp\u00e9cifiques.","type":"array","items":{"type":"string"},"required":false},"roles":{"description":"Limiter le r\u00e9sultat aux comptes correspondants \u00e0 au moins un r\u00f4le sp\u00e9cifique fourni. Accepte les listes de type CSV ou les r\u00f4les uniques.","type":"array","items":{"type":"string"},"required":false},"capabilities":{"description":"Limiter le jeu de r\u00e9sultats aux comptes correspondant \u00e0 au moins une capacit\u00e9 sp\u00e9cifique fournie. Accepte une liste CSV ou une capacit\u00e9 unique.","type":"array","items":{"type":"string"},"required":false},"who":{"description":"Limiter le jeu de r\u00e9sultats aux comptes consid\u00e9r\u00e9s comme auteurs ou autrices.","type":"string","enum":["authors"],"required":false},"has_published_posts":{"description":"Limiter les r\u00e9sultats aux comptes qui ont mis en ligne des publications.","type":["boolean","array"],"items":{"type":"string","enum":{"post":"post","page":"page","attachment":"attachment","nav_menu_item":"nav_menu_item","wp_block":"wp_block","wp_template":"wp_template","wp_template_part":"wp_template_part","wp_global_styles":"wp_global_styles","wp_navigation":"wp_navigation","wp_font_family":"wp_font_family","wp_font_face":"wp_font_face","sfwd-courses":"sfwd-courses","sfwd-lessons":"sfwd-lessons","sfwd-topic":"sfwd-topic","sfwd-quiz":"sfwd-quiz","sfwd-question":"sfwd-question","ld-exam":"ld-exam","groups":"groups","sfwd-essays":"sfwd-essays","sfwd-assignment":"sfwd-assignment"}},"required":false},"search_columns":{"default":[],"description":"Tableau de nom de colonnes \u00e0 rechercher.","type":"array","items":{"enum":["email","name","id","username","slug"],"type":"string"},"required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"username":{"description":"Nom de connexion pour le compte.","type":"string","required":true},"name":{"description":"Nom affich\u00e9 pour le compte.","type":"string","required":false},"first_name":{"description":"Pr\u00e9nom associ\u00e9 au compte.","type":"string","required":false},"last_name":{"description":"Nom du compte.","type":"string","required":false},"email":{"description":"L\u2019adresse e-mail du compte.","type":"string","format":"email","required":true},"url":{"description":"URL de ce compte.","type":"string","format":"uri","required":false},"description":{"description":"Description du compte.","type":"string","required":false},"locale":{"description":"Langue du compte.","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","it_IT","pt_PT"],"required":false},"nickname":{"description":"Le surnom du compte.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le compte.","type":"string","required":false},"roles":{"description":"R\u00f4les assign\u00e9s au compte.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Mot de passe pour le compte (jamais inclus).","type":"string","required":true},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"La date et l\u2019heure auxquelles les pr\u00e9f\u00e9rences ont \u00e9t\u00e9 mises \u00e0 jour.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/users"}]}},"\/wp\/v2\/users\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le compte.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le compte.","type":"integer","required":false},"username":{"description":"Nom de connexion pour le compte.","type":"string","required":false},"name":{"description":"Nom affich\u00e9 pour le compte.","type":"string","required":false},"first_name":{"description":"Pr\u00e9nom associ\u00e9 au compte.","type":"string","required":false},"last_name":{"description":"Nom du compte.","type":"string","required":false},"email":{"description":"L\u2019adresse e-mail du compte.","type":"string","format":"email","required":false},"url":{"description":"URL de ce compte.","type":"string","format":"uri","required":false},"description":{"description":"Description du compte.","type":"string","required":false},"locale":{"description":"Langue du compte.","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","it_IT","pt_PT"],"required":false},"nickname":{"description":"Le surnom du compte.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le compte.","type":"string","required":false},"roles":{"description":"R\u00f4les assign\u00e9s au compte.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Mot de passe pour le compte (jamais inclus).","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"La date et l\u2019heure auxquelles les pr\u00e9f\u00e9rences ont \u00e9t\u00e9 mises \u00e0 jour.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique pour le compte.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les comptes ne prennent pas en charge la suppression forc\u00e9e.","required":false},"reassign":{"type":"integer","description":"R\u00e9affectez les publications et les liens du compte supprim\u00e9 \u00e0 cet ID de compte.","required":true}}}]},"\/wp\/v2\/users\/me":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"username":{"description":"Nom de connexion pour le compte.","type":"string","required":false},"name":{"description":"Nom affich\u00e9 pour le compte.","type":"string","required":false},"first_name":{"description":"Pr\u00e9nom associ\u00e9 au compte.","type":"string","required":false},"last_name":{"description":"Nom du compte.","type":"string","required":false},"email":{"description":"L\u2019adresse e-mail du compte.","type":"string","format":"email","required":false},"url":{"description":"URL de ce compte.","type":"string","format":"uri","required":false},"description":{"description":"Description du compte.","type":"string","required":false},"locale":{"description":"Langue du compte.","type":"string","enum":["","en_US","de_DE","es_ES","fr_FR","it_IT","pt_PT"],"required":false},"nickname":{"description":"Le surnom du compte.","type":"string","required":false},"slug":{"description":"Un identificateur alphanum\u00e9rique pour le compte.","type":"string","required":false},"roles":{"description":"R\u00f4les assign\u00e9s au compte.","type":"array","items":{"type":"string"},"required":false},"password":{"description":"Mot de passe pour le compte (jamais inclus).","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"persisted_preferences":{"type":"object","title":"","description":"","default":[],"context":["edit"],"properties":{"_modified":{"description":"La date et l\u2019heure auxquelles les pr\u00e9f\u00e9rences ont \u00e9t\u00e9 mises \u00e0 jour.","type":"string","format":"date-time","readonly":false}},"additionalProperties":true}},"required":false}}},{"methods":["DELETE"],"args":{"force":{"type":"boolean","default":false,"description":"N\u00e9cessite la valeur \u00ab\u00a0true\u00a0\u00bb, car les comptes ne prennent pas en charge la suppression forc\u00e9e.","required":false},"reassign":{"type":"integer","description":"R\u00e9affectez les publications et les liens du compte supprim\u00e9 \u00e0 cet ID de compte.","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/users\/me"}]}},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords":{"namespace":"wp\/v2","methods":["GET","POST","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST"],"args":{"app_id":{"description":"Un UUID fourni par l\u2019application pour l\u2019identifier de mani\u00e8re unique. Il est recommand\u00e9 d\u2019utiliser un UUID v5 avec l\u2019URL ou l\u2019espace de noms DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Le nom du mot de passe de l\u2019application.","type":"string","minLength":1,"pattern":".*\\S.*","required":true}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/introspect":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/users\/(?P<user_id>(?:[\\d]+|me))\/application-passwords\/(?P<uuid>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"app_id":{"description":"Un UUID fourni par l\u2019application pour l\u2019identifier de mani\u00e8re unique. Il est recommand\u00e9 d\u2019utiliser un UUID v5 avec l\u2019URL ou l\u2019espace de noms DNS.","type":"string","oneOf":[{"type":"string","format":"uuid"},{"type":"string","enum":[""]}],"required":false},"name":{"description":"Le nom du mot de passe de l\u2019application.","type":"string","minLength":1,"pattern":".*\\S.*","required":false}}},{"methods":["DELETE"],"args":[]}]},"\/wp\/v2\/comments":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"after":{"description":"Limiter les r\u00e9ponses aux commentaires publi\u00e9s apr\u00e8s une date donn\u00e9e et conforme ISO8601.","type":"string","format":"date-time","required":false},"author":{"description":"Limiter le jeu de r\u00e9sultats aux commentaires assign\u00e9s aux ID de compte sp\u00e9cifi\u00e9s. N\u00e9cessite des droits sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"author_exclude":{"description":"S\u2019assurer que le jeu de r\u00e9sultats exclut les commentaires assign\u00e9s aux ID des comptes sp\u00e9cifi\u00e9s. N\u00e9cessite des droits sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"author_email":{"default":null,"description":"Limiter le jeu de r\u00e9sultats \u00e0 une adresse e-mail d\u2019auteur ou d\u2019autrice sp\u00e9cifique. N\u00e9cessite les droits correspondants.","format":"email","type":"string","required":false},"before":{"description":"Limiter les r\u00e9ponses aux commentaires publi\u00e9s avant une date donn\u00e9e et conforme ISO8601.","type":"string","format":"date-time","required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attribut de commentaire.","type":"string","default":"date_gmt","enum":["date","date_gmt","id","include","post","parent","type"],"required":false},"parent":{"default":[],"description":"Limiter le jeu de r\u00e9sultats aux commentaires ayant un ID parent sp\u00e9cifique.","type":"array","items":{"type":"integer"},"required":false},"parent_exclude":{"default":[],"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID parents sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"post":{"default":[],"description":"Limite le jeu de r\u00e9sultats aux commentaires assign\u00e9s \u00e0 des ID de publications sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"required":false},"status":{"default":"approve","description":"Limiter le jeu de r\u00e9sultats aux commentaires assign\u00e9s \u00e0 un \u00e9tat sp\u00e9cifique. N\u00e9cessite les droits correspondants.","type":"string","required":false},"type":{"default":"comment","description":"Limite le jeu de r\u00e9sultats aux commentaires assign\u00e9s \u00e0 un type sp\u00e9cifique. N\u00e9cessite des droits sp\u00e9cifiques.","type":"string","required":false},"password":{"description":"Le mot de passe pour cette publication, si celle-ci est prot\u00e9g\u00e9e par un mot de passe.","type":"string","required":false}}},{"methods":["POST"],"args":{"author":{"description":"L\u2019ID de l\u2019objet <code>user<\/code>, si l\u2019auteur ou l\u2019autrice \u00e9tait un compte.","type":"integer","required":false},"author_email":{"description":"Adresse e-mail de l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"email","required":false},"author_ip":{"description":"Adresse IP de l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"ip","required":false},"author_name":{"description":"Nom affich\u00e9 pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","required":false},"author_url":{"description":"URL pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agent utilisateur pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","required":false},"content":{"description":"Le contenu pour le commentaire.","type":"object","properties":{"raw":{"description":"Contenu pour le commentaire, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour le commentaire, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"La date \u00e0 laquelle le commentaire a \u00e9t\u00e9 publi\u00e9, dans le fuseau horaire du site.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"La date \u00e0 laquelle le commentaire a \u00e9t\u00e9 publi\u00e9, au format GMT.","type":"string","format":"date-time","required":false},"parent":{"default":0,"description":"L\u2019ID du parent du commentaire.","type":"integer","required":false},"post":{"default":0,"description":"L\u2019ID de l\u2019objet publication associ\u00e9.","type":"integer","required":false},"status":{"description":"\u00c9tat du commentaire.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"\u00c9tat de r\u00e9solution de la note","default":"","enum":["resolved","reopen"]}},"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/comments"}]}},"\/wp\/v2\/comments\/(?P<id>[\\d]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"Identifiant unique du commentaire.","type":"integer","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"password":{"description":"Mot de passe de la publication parente du commentaire (si la publication est prot\u00e9g\u00e9e par un mot de passe).","type":"string","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"id":{"description":"Identifiant unique du commentaire.","type":"integer","required":false},"author":{"description":"L\u2019ID de l\u2019objet <code>user<\/code>, si l\u2019auteur ou l\u2019autrice \u00e9tait un compte.","type":"integer","required":false},"author_email":{"description":"Adresse e-mail de l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"email","required":false},"author_ip":{"description":"Adresse IP de l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"ip","required":false},"author_name":{"description":"Nom affich\u00e9 pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","required":false},"author_url":{"description":"URL pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","format":"uri","required":false},"author_user_agent":{"description":"Agent utilisateur pour l\u2019auteur ou l\u2019autrice du commentaire.","type":"string","required":false},"content":{"description":"Le contenu pour le commentaire.","type":"object","properties":{"raw":{"description":"Contenu pour le commentaire, tel qu\u2019il existe dans la base de donn\u00e9es.","type":"string","context":["edit"]},"rendered":{"description":"Contenu HTML pour le commentaire, transform\u00e9 pour l\u2019affichage.","type":"string","context":["view","edit","embed"],"readonly":true}},"required":false},"date":{"description":"La date \u00e0 laquelle le commentaire a \u00e9t\u00e9 publi\u00e9, dans le fuseau horaire du site.","type":"string","format":"date-time","required":false},"date_gmt":{"description":"La date \u00e0 laquelle le commentaire a \u00e9t\u00e9 publi\u00e9, au format GMT.","type":"string","format":"date-time","required":false},"parent":{"description":"L\u2019ID du parent du commentaire.","type":"integer","required":false},"post":{"description":"L\u2019ID de l\u2019objet publication associ\u00e9.","type":"integer","required":false},"status":{"description":"\u00c9tat du commentaire.","type":"string","required":false},"meta":{"description":"Champs m\u00e9tas.","type":"object","properties":{"_wp_note_status":{"type":"string","title":"","description":"\u00c9tat de r\u00e9solution de la note","default":"","enum":["resolved","reopen"]}},"required":false}}},{"methods":["DELETE"],"args":{"id":{"description":"Identifiant unique du commentaire.","type":"integer","required":false},"force":{"type":"boolean","default":false,"description":"Que ce soit pour \u00e9viter la corbeille ou forcer la suppression.","required":false},"password":{"description":"Mot de passe de la publication parente du commentaire (si la publication est prot\u00e9g\u00e9e par un mot de passe).","type":"string","required":false}}}]},"\/wp\/v2\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"type":{"default":"post","description":"Limiter les r\u00e9sultats aux \u00e9l\u00e9ments d\u2019un type d\u2019objet.","type":"string","enum":["post","term","post-format"],"required":false},"subtype":{"default":"any","description":"Limiter les r\u00e9sultats aux \u00e9l\u00e9ments d\u2019un ou plusieurs sous-types d\u2019objet.","type":"array","items":{"enum":["post","page","sfwd-courses","sfwd-lessons","sfwd-topic","sfwd-quiz","ld-exam","sfwd-essays","sfwd-assignment","category","post_tag","ld_topic_category","ld_topic_tag","any"],"type":"string"},"required":false},"exclude":{"description":"S\u2019assure que le jeu de r\u00e9sultats exclut des ID sp\u00e9cifiques.","type":"array","items":{"type":"integer"},"default":[],"required":false},"include":{"description":"Limiter le groupe de r\u00e9sultats aux ID sp\u00e9cifi\u00e9s.","type":"array","items":{"type":"integer"},"default":[],"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/search"}]}},"\/wp\/v2\/block-renderer\/(?P<name>[a-z0-9-]+\/[a-z0-9-]+)":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET","POST"],"args":{"name":{"description":"Nom unique enregistr\u00e9 de ce bloc.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["edit"],"default":"view","required":false},"attributes":{"description":"Attributs pour le bloc.","type":"object","default":[],"required":false},"post_id":{"description":"ID de ce contenu\/contexte.","type":"integer","required":false}}}]},"\/wp\/v2\/block-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Espace de nom du bloc.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/block-types"}]}},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"namespace":{"description":"Espace de nom du bloc.","type":"string","required":false}}}]},"\/wp\/v2\/block-types\/(?P<namespace>[a-zA-Z0-9_-]+)\/(?P<name>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nom du bloc.","type":"string","required":false},"namespace":{"description":"Espace de nom du bloc.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/settings":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":[]},{"methods":["POST","PUT","PATCH"],"args":{"wordpress_api_key":{"title":"Cl\u00e9 de l\u2019API de Akismet Anti-spam","description":"Cl\u00e9 de l\u2019API du connecteur \u00ab\u00a0Akismet Anti-spam\u00a0\u00bb.","type":"string","required":false},"themeisle_sdk_promotions":{"title":"","description":"","type":"string","required":false},"themeisle_sdk_promotions_otter_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_optimole_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_rop_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_neve_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_redirection_cf7_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_hyve_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_wp_full_pay_installed":{"title":"","description":"","type":"boolean","required":false},"themeisle_sdk_promotions_masteriyo_installed":{"title":"","description":"","type":"boolean","required":false},"title":{"title":"Titre","description":"Titre du site.","type":"string","required":false},"description":{"title":"Slogan","description":"Slogan du site.","type":"string","required":false},"timezone":{"title":"","description":"Une ville dans le m\u00eame fuseau horaire que le v\u00f4tre.","type":"string","required":false},"date_format":{"title":"","description":"Un format de date commun pour tous les r\u00e9glages de dates.","type":"string","required":false},"time_format":{"title":"","description":"Un format d\u2019heure commun pour tous les r\u00e9glages d\u2019heures.","type":"string","required":false},"start_of_week":{"title":"","description":"Le num\u00e9ro du jour de la semaine \u00e0 laquelle la semaine devrait commencer.","type":"integer","required":false},"language":{"title":"","description":"Code local de l\u2019installation WordPress.","type":"string","required":false},"use_smilies":{"title":"","description":"Convertir les \u00e9motic\u00f4nes, comme :-) et :-P, en images lors de l\u2019affichage.","type":"boolean","required":false},"default_category":{"title":"","description":"Cat\u00e9gorie d\u2019article par d\u00e9faut.","type":"integer","required":false},"default_post_format":{"title":"","description":"Format d\u2019article par d\u00e9faut.","type":"string","required":false},"posts_per_page":{"title":"Nombre maximum de publications par page","description":"Les pages de blog affichent au maximum.","type":"integer","required":false},"show_on_front":{"title":"Affichage en page d\u2019accueil","description":"Afficher quoi sur la page d\u2019accueil","type":"string","required":false},"page_on_front":{"title":"Page d\u2019accueil","description":"L\u2019ID de la page qui doit \u00eatre affich\u00e9 sur la page d\u2019accueil","type":"integer","required":false},"page_for_posts":{"title":"","description":"L\u2019ID de la page qui affichera les derniers articles","type":"integer","required":false},"default_ping_status":{"title":"","description":"Autoriser les liens de notification d\u2019autres blogs (pings et r\u00e9troliens) sur les nouveaux articles.","type":"string","enum":["open","closed"],"required":false},"default_comment_status":{"title":"Autoriser les commentaires sur les nouvelles publications","description":"Autoriser les gens \u00e0 envoyer des commentaires sur les nouvelles publications.","type":"string","enum":["open","closed"],"required":false},"site_logo":{"title":"Logo","description":"Logo du site.","type":"integer","required":false},"site_icon":{"title":"Ic\u00f4ne","description":"Ic\u00f4ne du site.","type":"integer","required":false},"jwt_auth_options":{"title":"","description":"","type":"object","properties":{"share_data":{"type":"boolean","default":false}},"additionalProperties":false,"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/settings"}]}},"\/wp\/v2\/themes":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"status":{"description":"Limiter les r\u00e9sultats aux th\u00e8mes qui poss\u00e8dent un ou plusieurs \u00e9tats.","type":"array","items":{"enum":["active","inactive"],"type":"string"},"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/themes"}]}},"\/wp\/v2\/themes\/(?P<stylesheet>[^\\\/:<>\\*\\?\"\\|]+(?:\\\/[^\\\/:<>\\*\\?\"\\|]+)?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"stylesheet":{"description":"La feuille de style du th\u00e8me. Elle identifie le th\u00e8me de mani\u00e8re unique.","type":"string","required":false}}}]},"\/wp\/v2\/plugins":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"status":{"description":"Limiter les r\u00e9sultats aux extensions ayant l\u2019\u00e9tat sp\u00e9cifi\u00e9.","type":"array","items":{"type":"string","enum":["inactive","active","network-active"]},"required":false}}},{"methods":["POST"],"args":{"slug":{"type":"string","description":"Slug sur le r\u00e9pertoire des extensions WordPress.org.","pattern":"[\\w\\-]+","required":true},"status":{"description":"L\u2019\u00e9tat d\u2019activation de l\u2019extension.","type":"string","enum":["inactive","active","network-active"],"default":"inactive","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/plugins"}]}},"\/wp\/v2\/plugins\/(?P<plugin>[^.\\\/]+(?:\\\/[^.\\\/]+)?)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false},"status":{"description":"L\u2019\u00e9tat d\u2019activation de l\u2019extension.","type":"string","enum":["inactive","active","network-active"],"required":false}}},{"methods":["DELETE"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"plugin":{"type":"string","pattern":"[^.\\\/]+(?:\\\/[^.\\\/]+)?","required":false}}}]},"\/wp\/v2\/sidebars":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/sidebars"}]}},"\/wp\/v2\/sidebars\/(?P<id>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID d\u2019une colonne lat\u00e9rale enregistr\u00e9e","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"args":{"widgets":{"description":"Widgets imbriqu\u00e9s.","type":"array","items":{"type":["object","string"]},"required":false}}}]},"\/wp\/v2\/widget-types":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/widget-types"}]}},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"id":{"description":"L\u2019ID du type de widget.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/encode":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"L\u2019ID du type de widget.","type":"string","required":true},"instance":{"description":"R\u00e9glages de l\u2019instance courante du widget.","type":"object","required":false},"form_data":{"description":"Les donn\u00e9es s\u00e9rialis\u00e9es du formulaire du widget \u00e0 encoder dans les r\u00e9glages de l\u2019instance.","type":"string","required":false}}}]},"\/wp\/v2\/widget-types\/(?P<id>[a-zA-Z0-9_-]+)\/render":{"namespace":"wp\/v2","methods":["POST"],"endpoints":[{"methods":["POST"],"args":{"id":{"description":"L\u2019ID du type de widget.","type":"string","required":true},"instance":{"description":"R\u00e9glages de l\u2019instance courante du widget.","type":"object","required":false}}}]},"\/wp\/v2\/widgets":{"namespace":"wp\/v2","methods":["GET","POST"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"sidebar":{"description":"La colonne lat\u00e9rale pour laquelle renvoyer les widgets.","type":"string","required":false}}},{"methods":["POST"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique du widget.","type":"string","required":false},"id_base":{"description":"Type de widget. Correspond \u00e0 l\u2019ID du point de terminaison widget-types.","type":"string","required":false},"sidebar":{"default":"wp_inactive_widgets","description":"La colonne lat\u00e9rale \u00e0 laquelle appartient le widget.","type":"string","required":true},"instance":{"description":"R\u00e9glages de l\u2019instance du widget, si pris en charge.","type":"object","properties":{"encoded":{"description":"Repr\u00e9sentation des r\u00e9glages de l\u2019instance encod\u00e9e en base64.","type":"string","context":["edit"]},"hash":{"description":"Cl\u00e9 cryptographique hach\u00e9e des r\u00e9glages de l\u2019instance.","type":"string","context":["edit"]},"raw":{"description":"R\u00e9glages de l\u2019instance non encod\u00e9s, si pris en charge.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Donn\u00e9e de formulaire encod\u00e9e dans une URL pour le formulaire de l\u2019administration des widgets. Utilis\u00e9 pour mettre \u00e0 jour un widget qui ne prend pas en charge les instances. En \u00e9criture uniquement.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/widgets"}]}},"\/wp\/v2\/widgets\/(?P<id>[\\w\\-]+)":{"namespace":"wp\/v2","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET"],"allow_batch":{"v1":true},"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}},{"methods":["POST","PUT","PATCH"],"allow_batch":{"v1":true},"args":{"id":{"description":"Identificateur unique du widget.","type":"string","required":false},"id_base":{"description":"Type de widget. Correspond \u00e0 l\u2019ID du point de terminaison widget-types.","type":"string","required":false},"sidebar":{"description":"La colonne lat\u00e9rale \u00e0 laquelle appartient le widget.","type":"string","required":false},"instance":{"description":"R\u00e9glages de l\u2019instance du widget, si pris en charge.","type":"object","properties":{"encoded":{"description":"Repr\u00e9sentation des r\u00e9glages de l\u2019instance encod\u00e9e en base64.","type":"string","context":["edit"]},"hash":{"description":"Cl\u00e9 cryptographique hach\u00e9e des r\u00e9glages de l\u2019instance.","type":"string","context":["edit"]},"raw":{"description":"R\u00e9glages de l\u2019instance non encod\u00e9s, si pris en charge.","type":"object","context":["edit"]}},"required":false},"form_data":{"description":"Donn\u00e9e de formulaire encod\u00e9e dans une URL pour le formulaire de l\u2019administration des widgets. Utilis\u00e9 pour mettre \u00e0 jour un widget qui ne prend pas en charge les instances. En \u00e9criture uniquement.","type":"string","required":false}}},{"methods":["DELETE"],"allow_batch":{"v1":true},"args":{"force":{"description":"Indique s\u2019il faut forcer la suppression du widget ou le d\u00e9placer vers la colonne lat\u00e9rale inactive.","type":"boolean","required":false}}}]},"\/wp\/v2\/block-directory\/search":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"term":{"description":"Limiter les r\u00e9sultats aux blocs correspondant au terme de recherche.","type":"string","minLength":1,"required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/block-directory\/search"}]}},"\/wp\/v2\/pattern-directory\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":100,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","minLength":1,"required":false},"category":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 l\u2019identifiant d\u2019une cat\u00e9gorie.","type":"integer","minimum":1,"required":false},"keyword":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 un identifiant de mot-cl\u00e9.","type":"integer","minimum":1,"required":false},"slug":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une composition (slug).","type":"array","required":false},"offset":{"description":"Ignorer un nombre sp\u00e9cifique d\u2019\u00e9l\u00e9ments au sein du jeu de r\u00e9sultats.","type":"integer","required":false},"order":{"description":"Le param\u00e8tre order trie les attributs dans l\u2019ordre croissant ou d\u00e9croissant.","type":"string","default":"desc","enum":["asc","desc"],"required":false},"orderby":{"description":"Trier la collection par attributs de publication.","type":"string","default":"date","enum":["author","date","id","include","modified","parent","relevance","slug","include_slugs","title","favorite_count"],"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/pattern-directory\/patterns"}]}},"\/wp\/v2\/block-patterns\/patterns":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/block-patterns\/patterns"}]}},"\/wp\/v2\/block-patterns\/categories":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/block-patterns\/categories"}]}},"\/wp-site-health\/v1":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-site-health\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp-site-health\/v1"}]}},"\/wp-site-health\/v1\/tests\/background-updates":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp-site-health\/v1\/tests\/background-updates"}]}},"\/wp-site-health\/v1\/tests\/loopback-requests":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp-site-health\/v1\/tests\/loopback-requests"}]}},"\/wp-site-health\/v1\/tests\/https-status":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp-site-health\/v1\/tests\/https-status"}]}},"\/wp-site-health\/v1\/tests\/dotorg-communication":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp-site-health\/v1\/tests\/dotorg-communication"}]}},"\/wp-site-health\/v1\/tests\/authorization-header":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp-site-health\/v1\/tests\/authorization-header"}]}},"\/wp-site-health\/v1\/directory-sizes":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp-site-health\/v1\/directory-sizes"}]}},"\/wp-site-health\/v1\/tests\/page-cache":{"namespace":"wp-site-health\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp-site-health\/v1\/tests\/page-cache"}]}},"\/wp-block-editor\/v1":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-block-editor\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp-block-editor\/v1"}]}},"\/wp-block-editor\/v1\/url-details":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"url":{"description":"L\u2019URL \u00e0 traiter.","type":"string","format":"uri","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp-block-editor\/v1\/url-details"}]}},"\/wp\/v2\/menu-locations":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/menu-locations"}]}},"\/wp\/v2\/menu-locations\/(?P<location>[\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"location":{"description":"Un identificateur alphanum\u00e9rique pour l\u2019emplacement de menu.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-block-editor\/v1\/export":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp-block-editor\/v1\/export"}]}},"\/wp-block-editor\/v1\/navigation-fallback":{"namespace":"wp-block-editor\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":[]}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp-block-editor\/v1\/navigation-fallback"}]}},"\/wp\/v2\/font-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/font-collections"}]}},"\/wp\/v2\/font-collections\/(?P<slug>[\\\/\\w-]+)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp-abilities\/v1":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"namespace":{"default":"wp-abilities\/v1","required":false},"context":{"default":"view","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp-abilities\/v1"}]}},"\/wp-abilities\/v1\/categories":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp-abilities\/v1\/categories"}]}},"\/wp-abilities\/v1\/categories\/(?P<slug>[a-z0-9]+(?:-[a-z0-9]+)*)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Identifiant unique de la cat\u00e9gorie de fonctionnalit\u00e9s.","type":"string","pattern":"^[a-z0-9]+(?:-[a-z0-9]+)*$","required":false}}}]},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+?)\/run":{"namespace":"wp-abilities\/v1","methods":["GET","POST","PUT","PATCH","DELETE"],"endpoints":[{"methods":["GET","POST","PUT","PATCH","DELETE"],"args":{"name":{"description":"Identifiant unique de l\u2019\u00ab\u00a0ability\u00a0\u00bb.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false},"input":{"description":"Param\u00e8tres d\u2019entr\u00e9e pour l\u2019ex\u00e9cution de cette \u00ab\u00a0ability\u00a0\u00bb.","type":["integer","number","boolean","string","array","object","null"],"default":null,"required":false}}}]},"\/wp-abilities\/v1\/abilities":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":50,"minimum":1,"maximum":100,"required":false},"category":{"description":"Limiter les r\u00e9sultats aux \u00ab\u00a0abilities\u00a0\u00bb d\u2019une cat\u00e9gorie sp\u00e9cifique.","type":"string","required":false},"namespace":{"description":"Limiter les r\u00e9sultats aux \u00ab\u00a0abilities\u00a0\u00bb d\u2019une cat\u00e9gorie sp\u00e9cifique.","type":"string","required":false},"meta":{"description":"Limiter les r\u00e9sultats aux \u00ab\u00a0abilities\u00a0\u00bb correspondant \u00e0 tous les champs m\u00e9ta fournis.","type":"object","properties":{"annotations":{"description":"Limiter les r\u00e9sultats aux \u00ab\u00a0abilities\u00a0\u00bb correspondant aux annotations fournies.","type":"object","properties":{"readonly":{"description":"D\u00e9termine si cette \u00ab\u00a0ability\u00a0\u00bb ne modifie pas son environnement.","type":["boolean","null"]},"destructive":{"description":"D\u00e9termine si cette \u00ab\u00a0ability\u00a0\u00bb peut effectuer des mises \u00e0 jour destructrices sur cet environnement.","type":["boolean","null"]},"idempotent":{"description":"Les appels r\u00e9p\u00e9t\u00e9s avec les m\u00eames arguments n\u2019ont aucun effet suppl\u00e9mentaire.","type":["boolean","null"]}},"additionalProperties":true}},"additionalProperties":true,"required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp-abilities\/v1\/abilities"}]}},"\/wp-abilities\/v1\/abilities\/(?P<name>[a-zA-Z0-9\\-\\\/]+)":{"namespace":"wp-abilities\/v1","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Identifiant unique de l\u2019\u00ab\u00a0ability\u00a0\u00bb.","type":"string","pattern":"^[a-zA-Z0-9\\-\\\/]+$","required":false}}}]},"\/wp\/v2\/icons":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false},"collection":{"description":"Limiter les r\u00e9sultats aux ic\u00f4nes qui appartiennent au slug de la collection fournie.","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/icons"}]}},"\/wp\/v2\/icons\/(?P<collection>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"collection":{"description":"Limiter les r\u00e9sultats aux ic\u00f4nes qui appartiennent au slug de la collection fournie.","type":"string","pattern":"^[a-z0-9]([a-z0-9_-]*[a-z0-9])?$","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false}}}]},"\/wp\/v2\/icons\/(?P<name>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?\/[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"name":{"description":"Nom de l\u2019ic\u00f4ne.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/icon-collections":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false},"page":{"description":"Page courante dans la collection.","type":"integer","default":1,"minimum":1,"required":false},"per_page":{"description":"Nombre maximal d\u2019\u00e9l\u00e9ments \u00e0 retourner dans le groupe de r\u00e9sultats.","type":"integer","default":10,"minimum":1,"maximum":100,"required":false},"search":{"description":"Limiter les r\u00e9sultats \u00e0 ceux qui correspondent \u00e0 une cha\u00eene de caract\u00e8res.","type":"string","required":false}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/icon-collections"}]}},"\/wp\/v2\/icon-collections\/(?P<slug>[a-z0-9](?:[a-z0-9_-]*[a-z0-9])?)":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"slug":{"description":"Slug de la collection d\u2019ic\u00f4nes.","type":"string","required":false},"context":{"description":"Le contexte dans lequel la demande est faite\u00a0; cela d\u00e9termine les champs renvoy\u00e9s.","type":"string","enum":["view","embed","edit"],"default":"view","required":false}}}]},"\/wp\/v2\/view-config":{"namespace":"wp\/v2","methods":["GET"],"endpoints":[{"methods":["GET"],"args":{"kind":{"description":"Type d\u2019entit\u00e9.","type":"string","required":true},"name":{"description":"Nom de l\u2019entit\u00e9.","type":"string","required":true}}}],"_links":{"self":[{"href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/view-config"}]}}},"site_logo":25019,"site_icon":26065,"site_icon_url":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-content\/uploads\/sites\/5\/2020\/04\/favicon.ico","_links":{"help":[{"href":"https:\/\/developer.wordpress.org\/rest-api\/"}],"wp:featuredmedia":[{"embeddable":true,"type":"site_logo","href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/media\/25019"},{"embeddable":true,"type":"site_icon","href":"https:\/\/bimsoftwaretraining.accasoftware.com\/fr\/wp-json\/wp\/v2\/media\/26065"}],"curies":[{"name":"wp","href":"https:\/\/api.w.org\/{rel}","templated":true}]}}
